How to JTAG a DM500
  • aalkhaldi
    hello,
    that's it what i need. i hope it will work because it's my firsttime.
    thx
    • fricker
      • 543
      #182
      hi. i have problem to flash boot to dm500s JS28F640 with philips tuner. this DM is new and i will chang MAC . i write MAC in bat file and start boot uploud and all is fine. problem is that after uploud tuner cant find satelites and have other problems. maybe this philips sw is for cable tuner ? i have flashed ALPH and all is fine . how to flash this philips tuner ?
      • jbvid
        • 261
        #183
        @fricker
        Hi
        If you have the option to do a Satellite scan you have the correct bootloader, but you mention you flashed Alps, this is wrong.
        If your dm has philips tuner jtag command line like this.
        "jtagdm500 -m dm500 -d philips" without quotes.
        jbvid
        • sparktikus
          • 31
          #184
          donton how did you get yours working
          i have the dm500c with nxp tuner have you got the correct blimg files to get this running
          • micromouse
            • 162
            #185
            22222222222222222222222222222222
            • jbvid
              • 261
              #186
              @micromouse
              Hi
              Very interesting post BTW, I just have one, well two really questions for a dm500c clone bootloader, after generating the file with the generator I presume you have to rename the file to 'blimp' then put it in the correct folder with jtag_windows.exe? Also does it matter about entering the correct Mac address into the generator or just use your 'something like' posted figures?
              Regards jbvid
              • sparktikus
                • 31
                #187
                micromouse i have tried the mac generator (cable) for my dm500c but i cannot load it up via jtag windows ,, when i write it says "could not open flash.bin"
                i take it all i should be doing is renaming the mac generated file to blimg and it should load??? is that correct???
                • micromouse
                  • 162
                  #188
                  Last edited by micromouse; 12 September, 2013, 11:53. Reason: Automerged Doublepost
                  • sparktikus
                    • 31
                    #189
                    i have no problem in connecting 500c jtag
                    but error always comes up "could not load flash.bin" after renaming blimg and writing
                    but the blimg that comes standard in windows package (the wrong one default alps i think ) will write to the box with no error
                    what could be wrong
                    mine is nxp tuner
                    • micromouse
                      • 162
                      #190
                      • sparktikus
                        • 31
                        #191
                        micromouse
                        that file loaded fine !! thanks
                        i still have no response from box apart from green power light coming on
                        is that boot file file suitable for 500c nxp tuner?
                        i dont get no response in hyperterminal neither when powering up
                        is it lookin like a bin job on this 1
                        is the bootloader totally screwed?
                        • micromouse
                          • 162
                          #192
                          • jbvid
                            • 261
                            #193
                            @sparktikus
                            Hi
                            Did you disconnect you jtag wires and restart the PC before trying dreamup?
                            I couldn't get dreamup to connect after loading the 500c bootloader in until I disconnected my jtag setup and a PC reboot.
                            Worth a try.
                            @micromouse
                            Thanks for the ponters BTW.
                            jbvid
                            • sparktikus
                              • 31
                              #194
                              i have tried a few dreamups
                              and latest one of dream website
                              do you know if its possible to read bootloader info off a working dreambox and transfer info onto this box
                              • micromouse
                                • 162
                                #195
