I've got mine to work and flash OK, but now the box is recognized as DM56** and no video any suggestions
How to JTAG a DM500
Omar,
I tried your method, hooked up the jumper then switched to the next set and it still didn't connect, guess it's a dead dm 500.
Although when I do hit connect with it hooked up to a jtag it does make the red light come on.
It just can't be dead... time to get more determined,
[quote=revolte;12763]I've got mine to work and flash OK, but now the box is recognized as DM56** and no video any suggestion
use dream up
(Although when I do hit connect with it hooked up to a jtag it does make the red light come on.)Omar,
good ..now download firmware
try many time
Dear Omar,
Ok Will The Bootloader Fixed If Upgraded With rel109-20060803.img This Image.
Thanks.Comment
the philips bootloader ... okAttached Files
i have find other soft to get my dm to work
the interface is the same
LPT?????> Dreambox/Clone
2 ?> 100 ohms ?> 11 ( Halt)
3 ?> 100 ohms ?> 9 ( Tms )
4 ?> 100 ohms ?> 7 ( Tck )
5 ?> 100 ohms ?> 3 ( Tdi )
11 ?> 100 ohms ?> 1 ( Tdo )
25 ?????? 16 ( Ground)
Th pins 18, 19, 20, 21, 22, 23, 24 e 25 of the port LPT must be shunted between themselves.
the software is attached
first you connect the cable betwen dm and lpt port then power up the dm
then open a dos windows and execute the soft and enjoy
tested by me and work 100%
the soft name is jtagdm500 so you unzip the folder in c and open dos windows
c:\cd jtagdm500
c:\jtagdm500>jtagdm500 -m dm500 -i
you have some thing like this
C:\Jtagdm500>jtagdm500 -m dm500 -i
Dreambox Dm500 board initialize
Flash info. : INTEL JS28F640J3D75
[dm500] reading CA:03 ff 07 ff 0f ff 1f ff 3f ff 7f ff ff ff 00 10
[CA] Ho Ho! CloneWARS corrupted bootloader eh?! consider getting a IPBOX!
Readed Config Area
Configuration Area
Mac Address: 00:09:34:aa:0b:cc
Redunderant Mac Address: aa:0b:cc
Tuner Type alps
tham mean the communication is ok then
C:\Jtagdm500>jtagdm500 -m dm500 -e 00:09:34:00:11:22 -c
Readed Config Area
Configuration Area
Tuner Type alps
Mac Address Change Requested
Commit Config Area
Configuration Area
Mac Address: 00:09:34:00:11:22
Redunderant Mac Address: 00:11:22
Tuner Type alps
Erase Flash. done
Download......19%
enjoy
Attached FilesComment
