New Images for SG use only
  • fumoffuXx
    • Oct 2013
    • 6
    #526
    ok thank you ill request for a replacement. thanks
    • goldway
      #527
      image works great on DM800HD PVR. thank you.
      • fraggot
        • Nov 2013
        #528
        Hello everyone from SG Be careful when using USB to record!
        Recently had some problem with my box trying to record to USB flash disk. Basically the picture froze and when I restarted the box, it wouldn't boot with the flash disk inserted.
        So... pulled out the flash disk and when I booted the box again- I found that my box was broadcasting black on most of the channels.
        I went into setup and found that all the ccam info was missing.
        Itchy fingers me tried re-flashing via web browser with Open Pli 2.1-dm800-SSL-84b.nfi but only backed up this folder /usr/keys
        But now ALL my HD channels are missing! Yikes.
        Any bros care to help me out? I'd really appreciate any help. I'm using a clone DM800HD box
        • moviesg
          • Jul 2012
          • 60
          #529
          Hd missing since there was block upgrade
          Sent from my SM-N9005 using Tapatalk
          • moviesg
            • Jul 2012
            • 60
            #530
            This morning 12-6 am
            • krazyhippo
              • Oct 2013
              I believe its all blocked on all hd channels
              • fraggot
                • Nov 2013
                #532
                Wow I didn't know this! Thanks for the info guys.
                So I guess we just can't watch any HD channels from now on? That sucks.
                Sadface. Just got the box like a month ago.
                • Asbar
                  • Jun 2012
                  • 60
                  #533
                  block upgrade means for a while only or no more HD channels..?
                  • chiawy
                    • Aug 2012
                    • 9
                    #534
                    So shortly, all SD channels will also be on N3 with N1 turn off?
                    • acidjc
                      • Nov 2013
                      • 7
                      #535
                      by then when it happened, all our DM will become brick
                      • jatrophaseed
                        • 589
                        #536
                        Your brick is the foundation of my skyscraper tomorrow..........
                        • miong168
                          • Feb 2010
                          #537
                          Hi fragoot,
                          i had this problem before, i was using a portable hardrive. issue was the box's usb power is not enough to for the portable harddisk. what i did was look for a dual end usb cable (from an old HDD casing) one is for power (connected to my tv's usb power) and the other one to the cable box. it worked for me. try it.
                          • kokoronikui
                            • 73
                            #538
                            Finally dead.. Oh well.. perhaps someday a easy solution will surface.. RIP
                            • DBTraitor
                              • Feb 2011
                              • 616
                              #539
                              Bro Koonz uploaded this in the download section. Yes it is updated with latest channels, I just tried it.
                              PLI JADE 3 500C IMAGE FOR SG - Downloads - Digital Kaos
                              A wise man learn more from a foolish question than a fool can learn more from a wise answer.
                              • bosimao888
                                • Dec 2013
                                • 4
                                #540
                                just to check is this the latest update for sg channel?
