New Images for SG use only
  • iise7en
    • 9
    #436
    Originally posted by digi16
    Just few posts up ypvs posted an image with boutiques. That is all you need.
    You refer to #428 of this thread?
    All I need is to flash that nfi and that is it?
    • goodlands
      • Mar 2012
      • 52
      #437
      What are boutiques? Do you mean bouquets?
      • goodlands
        • Mar 2012
        • 52
        #438
        Anyone has DM800se Newnigma image v3.3.2 ... I know Master YPV posted v3.3.1 earlier but I'm suspecting the v3.3.2 handles signal better...
        • puptoon
          • Aug 2013
          • 22
          #439
          Originally posted by madjack
          You need a thumbdrive to connect to usb. Go to TS PANEL, look DEVICE MANAGER , press RED button to DISMOUNT & RED button again to MOUNT. Select No.1 as MAIN HDD & exit. Then you need to go to TS PANEL again to ADDON, under TUNISAT look for DFLASH PLUGIN. Once you manage to install Dflash, go to SYSTEM - SETUP - FLASHING & BACKUP, follow prompt & you are good to go. Wait for around 5 to 8 min. Once completed, you have to ftp the NFI FILE from your USB to PC to backup your FULL IMAGE.
          Credit:ZM00601
          I always having the message the enigma2 will restart due to insufficient swap space. After the restart, nothing was backup.The swap space is being set as default value. I wondering what is the recommend swap space? Hope u guys can help out. Wouldn't want to flash the image without backup of my current image. BTW I'm using a 8gb stick with fat32.
          Forgot to add that mine is the DM800 HD box
          Sent from my Nexus 7 using Tapatalk HD
          @IMgKSJ
          • uu161
            • May 2012
            • 372
            #440
            master db posted before do a search and alof of place also have
            if you like the post use the Like button located bottom right corner of each post
            if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
            • laclah
              • Apr 2013
              • 7
              #441
              Hi, I am looking for Newnigma image v3.3.2 for DM800HD, all the links are down, anyone can repost?
              • laclah
                • Apr 2013
                • 7
                #442
                You can dl DM800se Newnigma image v3.3.2 at
                SG-Newnigma V3.3.2-dm800se-SSL-84b - Downloads - Digital Kaos
                • pekakbadak15
                  • Mar 2012
                  • 103
                  #443
                  What i think is image does not relate to better signal. Factor like tuner or number of users watching tv on the same signal is the likely issue. Now trend is few subscribers but many tapping in on the same signal. V3.3.2 does not display correct character on the epg that is what i dislike.
                  • pekakbadak15
                    • Mar 2012
                    • 103
                    #444
                    @IMgKSJ
                    Are u using dflash plugin to backup? It can be downloaded via tspanel addon. For more important backup is the magic files, other files like bouquet or images can be get easily here in this forum
                    • puptoon
                      • Aug 2013
                      • 22
                      #445
                      Yup latest version of dflash v9.x. already mounted my usb and when I select backup it always show enigma2 will restart due to insufficient swap space. So I'm wondering what is the recommended swap space to be set.
                      Sent from my GT-N7000 using Tapatalk 4
                      • pekakbadak15
                        • Mar 2012
                        • 103
                        #446
                        Are u downloading it from tunisia addons? It is only dflash 3.3 available. Guess the newer version is meant for backing up original image.
                        • puptoon
                          • Aug 2013
                          • 22
                          #447
                          But I did try with version 3.3. It also prompt me the same thing that's y I installed the lastest v9.
                          • puptoon
                            • Aug 2013
                            • 22
                            #448
                            Alrite, I finally manage to backup the my image. I reformatted my usb stick on my mac. The last time my usb stick was formatted using my parallel win xp. Maybe it got corrupt. But anyways thanks for help. Learn something new. At the meantime lets enjoy the footy!
                            • DBTraitor
                              • Feb 2011
                              • 616
                              #449
                              @IMgKSJ
                              You have not mounted your usb correctly
                              A wise man learn more from a foolish question than a fool can learn more from a wise answer.
                              • puptoon
                                • Aug 2013
                                • 22
                                #450
                                I'm not sure whether the usb was mounted correctly. What I did was select mount > select the location to be mounted which I selected media/hdd. It did not prompt any error. Anyway thanks as I reformatted my usb stick again and manage to backup the image.
