You need DFlash to be install as your plug-ins onto the other box to backup an image of it's current overall configuration which will include the magic files into. Which you would then FTP over the file with *.nfi which will then upload as shown as your own images which you had it uploaded earlier and it will upgrade your faulty image with the clone copies. Of cos that makes your job easier with the information intact. Hope that helps. DO TAKE NOTE TO MOUNT A USB THUMBDRIVE TO PERFORM IMAGE BACKUP else your the other box might crashed due to space constraints. Cheers
New Images for SG use only
I have managed to boot up my dm800hdse after flashing the image. As asual, it was without the magic keys so o ly fta channels are available. Can you advise how can I get the necessary files and magic keys again for my set to work well. Thanks.You need DFlash to be install as your plug-ins onto the other box to backup an image of it's current overall configuration which will include the magic files into. Which you would then FTP over the file with *.nfi which will then upload as shown as your own images which you had it uploaded earlier and it will upgrade your faulty image with the clone copies. Of cos that makes your job easier with the information intact. Hope that helps. DO TAKE NOTE TO MOUNT A USB THUMBDRIVE TO PERFORM IMAGE BACKUP else your the other box might crashed due to space constraints. CheersComment
Do read back your message #493 which I had replied earlier on. But this time, use your other box which is working. Cheers mate
I used FlashFXP as outlined by the guides here,Do read back your message #493 which I had replied earlier on. But this time, use your other box which is working. Cheers mate
Click on Lightning arrow button
Click on Quick Connect
Connection type: FTP
Server or URL : 192.168.0.XX( the number shown on my dreambox as of now )
Port 21
User Name : root
Password : dreambox
RemotePath : left blank
Proxy Server : (defaut)
I keep getting this message :
'[R] Connecting to DM800HDSE -> IP=192.168.0.13 PORT=21 (attempt # 1)
[R] Connection failed (Connection refused)
[R] Delaying for 120 seconds before reconnect attempt #2
[R] Connecting to DM800HDSE -> IP=192.168.0.13 PORT=21 (attempt # 2)
[R] Delaying for 120 seconds before reconnect attempt #3
[R] Connecting to DM800HDSE -> IP=192.168.0.13 PORT=21 (attempt # 3)
[R] Delaying for 120 seconds before reconnect attempt #4
[R] Connecting to DM800HDSE -> IP=192.168.0.13 PORT=21 (attempt # 4)
[R] Delaying for 120 seconds before reconnect attempt #5'
I asked the seller and is clueless about the software user/password except selling the units.
if it is an issue of a different password, can I reset it and retry the FTPComment
Can you try it on another FTP software probably FileZilla or CoffeeFTP just to confirm not getting in to the box! Cos from what I see here is Read / Login error which is kind of odd. Can you ping to the box!
Port 21
User Name : root
Password : dreambox
FTP service might not be loaded. Use your PC web browser with display iP address. See if you can get the boot menu and load the images from there.I used FlashFXP as outlined by the guides here,
Port 21
User Name : root
Password : dreambox
How to FTP
How to FTP Picons for 500C - YouTube
Dreambox Flashing for 800HD & 800SE
Dreambox Flashing for 800HD & 800SE - YouTubeLast edited by hockheng; 10 September, 2013, 18:09.Comment
sorry. newbie here. whats magic files?Open Pli 2.1-dm800-SSL-84b.nfi
Open Pli 2.1-dm800se-SSL-84b.nfi
While stocks last..
Credits to master AVGAL..
No magics files included.. backup your magic files 1st before flashing..Comment
Here is the link. Ftp yr own key files and restart softcam.
SG-Newnigma V3.3.1-dm800-SSL-84a.nfi
the link are down?
hi, can anyone help? guess i didn't backup magic files(infact i dunnoe how to backup also)Open Pli 2.1-dm800-SSL-84b.nfi
While stocks last..
now i cant view any channels
