SGSH E1 Online Bouquet plugin
  • ASTROBOX
    • 163
    #61
    Originally posted by forbezy2010
    i want to host my own file for download
    Try reading & understand this link on how to pack your bouquet before uploading to your own web hosting
    then do as master ypvs advise to change your url hosting in the script, do not change anything else or your channel list will not go to the correct folder as what i did from this experiment, as u can see the guide is for satellite receiver whereas ours is cable so i have to change the correct folder name to cater for cable receiver.
    Let us know the outcome of your experiment so we can help if there is something u miss
    • forbezy2010
      • Jul 2010
      • 12
      #62
      Originally posted by ypvs125
      Change the url to point to yr host file.
      i have changed the url to the one i want
      and all i get is a blank screen.
      • DBTraitor
        • Feb 2011
        • 616
        #63
        Alternative methods to ftp latest channels for SH
        Digital Kaos - Downloads - SG 500C Updated Channels 24112012
        Video Guide Included
        A wise man learn more from a foolish question than a fool can learn more from a wise answer.
        • forbezy2010
          • Jul 2010
          • 12
          #64
          i have files in a folder
          rar up then use izarc to convert to tar.gz
          i using this script
          #!/bin/sh
          echo "Updating latest SGSH Channels!"
          cd /tmp
          wget -q http://sgsh.ddns.net/E1sgsh.tar.gz -O E1sgsh.tar.gz 2> /dev/null
          wget -q http://e1sgsh.net-freaks.com/E1sgsh.tar.gz -O E1sgsh.tar.gz 2> /dev/null
          if [ ! -s /tmp/E1sgsh.tar.gz ] ; then
          echo ""
          echo "Connection Failed!"
          echo ""
          echo "Please check if your LAN are connected to Internet"
          rm -f /tmp/E1sgsh.tar.gz
          exit 0
          else
          cd /var/etc/
          rm -rf cables.xml
          rm -rf terrestrial.xml
          rm -rf satellites.xml
          cd /var/tuxbox/config/enigma/cable/
          rm -rf *.tv
          rm -rf *.radio
          rm -rf *.epl
          rm -rf *.epl
          rm -rf bouquets
          rm -rf services
          rm -rf services.locked
          rm -rf userbouquet*.*
          cd /
          chmod 755 /tmp/E1sgsh.tar.gz
          tar -zxvf /tmp/E1sgsh.tar.gz
          rm -rf /tmp/E1sgsh.tar.gz
          rm -rf /tmp/1E1sgsh.tar.gz
          echo ""
          echo "New Channels Updated Successfully!"
          echo ""
          chmod 755 /var/tuxbox/plugins/*.sh
          killall -q -9 enigma
          exit 0
          fi
          i kept the filename the same on my pc and on my site
          so all i had to do was change the wget line to the link i have.
          can anyone help me out.
          live help me on blackberry messenger ?
          • uu161
            • May 2012
            • 372
            #65
            well good luck on E1 plugin i had remove dns.
            if you like the post use the Like button located bottom right corner of each post
            if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
            • pekakbadak15
              • Mar 2012
              • 103
              #66
              Does that mean e1 boxes won't get online bouquet update anymore. Thought dbtraitor and astrobox is the one who is managing this.
              • DBTraitor
                • Feb 2011
                • 616
                #67
                I think the script still works, anyway do manual updates is the best. Not too much of a a hazzle too. Its only a 5 seconds job.
                • DBTraitor
                  • Feb 2011
                  • 616
                  #68
                  Latest Updated channels for 500c (6 Dec 2012)
                  Download 500c Service and Boquet Files updated 12062012.zip from Sendspace.com - send big files the easy way
                  • DBTraitor
                    • Feb 2011
                    • 616
                    #69
                    Is there any update script for E1? Is the one in download section still valid?
                    I just try to do an update however, was not successful. The script executed and reboot but channels not updated.
                    Digital Kaos - Downloads - SGSH E1 Online Bouquet plugin
                    • uu161
                      • May 2012
                      • 372
                      #70
                      the script are already a updated one
                      just need to replace new dns link and i had remove because someone posted the dns link here
                      • uu161
                        • May 2012
                        • 372
                        #71
                        i have put up the new dns link
                        give a try see it works?
                        and i had repack ur Bouquet and uploaded to server ^^
                        • DBTraitor
                          • Feb 2011
                          • 616
                          #72
                          Thanks alot for the prompt response. Btw I already updated those servers with new picon and bouquet for E1 few days back
                          • uu161
                            • May 2012
                            • 372
                            #73
                            yes i notice but packed wrong and won't get updated that why need repack
                            when u free download and unpack Bouquet to see the different
                            • Logger
                              • Feb 2011
                              • 92
                              #74
                              For the E1 update of channel, i just use dreambox edit to transfer the channel list. Pls do update if the auto update works. Hehe.
                              • DBTraitor
                                • Feb 2011
                                • 616
                                #75
                                Yes, i realise the difference.
                                Just curious, if I also pack the picon folder to it, will it also update the picons automatically?
                                By the way, the plugin is working good and I tested it.
                                Nicely done. Thank you very much and appreciate your time and effort.
