SGSH E1 Online Bouquet plugin
  • uu161
    • May 2012
    • 372
    #76
    yes it should work if picon folder are added in to Bouquet package
    if you like the post use the Like button located bottom right corner of each post
    if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
    • zaki1462
      • 9
      #77
      Hi guys...i tried the above plug-in for my dm500c...it installed and updated perfectly but the channels are not in order. Do i need to use DBedit to arrange it back?
      • ypvs125
        • Dec 2010
        • 506
        #78
        Personally, I have never tried using this plugin so I don't know and so far never see any feedback on it whether it is working or not. If u still need to use dbedit to rearrange the channels, then it defeat the purpose of having this plugins. If after using the plugins the channels are not in order, then u need to use dbedit.
        • Innercy
          • Dec 2012
          • 7
          #79
          Can someone update this plugin to install the latest bouquets? D:
          • ypvs125
            • Dec 2010
            • 506
            #80
            Why don't u try the plugin and leave feedback whether it is working or not as to benefit other user.
            • DBTraitor
              • Feb 2011
              • 616
              #81
              all is in order since day 1.........
              A wise man learn more from a foolish question than a fool can learn more from a wise answer.
              • zaki1462
                • 9
                #82
                The plug-in provided by Bro uu161 dated 10122012 got all the latest channels. However when i installed it the channels are not in running order. Do i need to rearrange it back or is it that way by default?
                • Koonz
                  • Dec 2012
                  • 63
                  #83
                  Should be ok unless you are using a different plugin?
                  Maybe wait for uu161 to test and let us know.........
                  • ypvs125
                    • Dec 2010
                    • 506
                    #84
                    It is good for us to feedback so that the issue can be solved as usually the one who creates and maintain this plugin would surely don't have a problem on their side.
                    • uu161
                      • May 2012
                      • 372
                      #85
                      Hi all for E1 I wouldn't test on my side coz I don't own any dm500c. Those who face channel number issue might want to post which image are you using? E1 Bouquet are maintain by master DB. Maybe when he free will double check
                      • DBTraitor
                        • Feb 2011
                        • 616
                        #86
                        i try and update you guys tomorrow night
                        • zaki1462
                          • 9
                          #87
                          Btw my image is PLiJade...
                          • ypvs125
                            • Dec 2010
                            • 506
                            #88
                            I installed the plugin just to test and it is working on my side and channels are in order too although at times i need to run the plugin twice to see the update is correct.
                            • DBTraitor
                              • Feb 2011
                              • 616
                              #89
                              yup, will update over the weekend
                              • zaki1462
                                • 9
                                #90
                                I have updated 2 dm500c image with the plugin included and can be downloaded below. Just ftp yr keys and scce folder and u r set to go. Ch809 is still not updated when u run the plugin so need to wait for dbtraitor updated bouquet.
                                SG-dm500c-OpenPli-19122012.img
                                SG-dm500c-OpenPLi-Turko-v22.img
                                So i just need to flash one of these images and ftp my current keys and scce folder and update thru the plug in. Is that rite bro?
