FY800HD
  • b3nzzz
    • Jul 2010
    • 4
    #151
    anybody able to have epl channels on their fy800 hd white set?
    • cyrus666
      • Aug 2013
      • 21
      #152
      i have tried manual scan with 6090 symbol rate with 128.5,139.5 and 149.5 i have only got bpl channels 229.230,231 the rest i could not get. Pls help me
      • croc
        • Jul 2012
        • 70
        #153
        139.5 or 135.5?
        • tammytan
          • Aug 2013
          • 15
          #154
          I finally found out that mine is the first gen FYHD800, can I use the firmware provided here on page 7?
          • cyrus666
            • Aug 2013
            • 21
            #155
            thanks for the reply, i have tried manual scan with 6090 symbol rate with 128.5,135.5,139.5 and 149.5 i have only got bpl channels 229.230,231 the rest i could not get. Pls help me
            • jerjan
              • 25
              #156
              Is EPL a must ?
              Let me contribute a bit, do not frame me if I am wrong
              I believe white box are unable to scan for 135.5 or 135 (any white box FYHD got the channel ?)
              It got nothing to do with signal strength.
              As for channel 232-233 (149.5) It is all at the 1000+ channel.
              You guys scan but did not go through all the channel............
              just my 1/2 cents worth
              • Thirtys37en
                • Aug 2013
                Hi im new here. Is there any firmware update for fyhd800cii & fyhd800ciii? Im not sure if those posted are meant for those sets.
                Im having the same problem with only having 229, 230, 231 n 233 B*L channel. Have tried manual tuning (using the freq shared) but no success.
                • amanosg
                  • Aug 2013
                  • 5
                  #158
                  Flashed FW from jatrospeed today. All systems go. mio Stadium channels are there (3x), plus other sports channels.
                  What I have: TNHD HDC888 (White)
                  • croc
                    • Jul 2012
                    • 70
                    #159
                    but i can't get leh
                    • tammytan
                      • Aug 2013
                      • 15
                      #160
                      Do you need to change the file name to FY.AP? Cos my set couldnt detect the file downloaded from page 7 here.
                      • moronicgenius
                        • Jun 2012
                        • 54
                        #161
                        u receiving 226-228 ok? these channels not running smooth for me, freeze every few sec.
                        • amanosg
                          • Aug 2013
                          • 5
                          #162
                          I didn't change anything. Downloaded the file. Put into usb drive. File ext is bin.
                          • amanosg
                            • Aug 2013
                            • 5
                            #163
                            Yes ok. After flashing, have to rescan. Took a while to do it, when completed, the sports channels were there and the channel sequence is in the correct order.
                            • cyrus666
                              • Aug 2013
                              • 21
                              #164
                              amanosg what box are you using.... i am using hd800c-vii but my channels are not in order and also i don,t have 226,227,228. I used the fw provided by jatrospeed
                              • tammytan
                                • Aug 2013
                                • 15
                                #165
                                Pardon me but I felt I really have to speak my mind. I have join this forum recently hoping I could get some help from fellow FYHD user. But it seems like most of them here are only interested in asking questions and not interested to help out. I tried to read thru most of the related threads but still dont get any answers. A simple yes/no or can/cannot would have been very much appreciated. Nevermind, I have given hope on getting any answer here. Thanks for reading.
