Guide: Flashing a Dreambox with Dreamup
    Well done m8 glad you got sorted
    • asif671
      • Apr 2010
      can not connect with box
      hi
      i am trying to connect with dream box but icant connect can any one help me plz
      • piopat
        • 708
        #363
        do you mean your trying to connect with dream control center or your trying to flash with dreamup ,we need more info please. what cables are you using , let us know.
        i love it when a dreambox comes together.
        • wackywayne
          hi everyone need a little bit of help
          i have a dreambox dm500-c and had a little accident
          i pressed panic button which after reading tells me that it removes all the guts from my flash image so i downloaded
          dk 1.1 from downloads section along with dreamup
          when i connect crossover cable i can not for the life me
          get it to connect so i tried the null cable which i have followed every guide to the letter when i connect and click connect it goes through its stages where it says connected and loading bootloader and that its speaking ok so i go to select the image i wont it starts to flash does about 5% and then says user aborted closing
          i have tried to explane the best i can so can someone please HELP ME! before i go out of my mind
          • mikeb
            • May 2010
            Thanx good explanation.
            • piopat
              • 708
              #366
              if dreamup says user aborted (even tho you didnt ) putting it simply that the version of dreamup you are using is not working as it should be ,so try an older version ofr dreamup first (if your box is a dm500) and a newer version if its a newer box .you can get dreamup from link 2 or link 3 in my signature area .
              • sema007
                • May 2010
                #367
                Originally posted by animal666
                need help again lads. i have connected a null modem cable to dreambox and pc.
                i load up dreamup and press connect. i then turn on the power but nothing happens.
                i am using com port 1 and the default local ip and remote ip. i have also tried to put in my dreambox ip address. but still nothing comes up.
                any help will be welcome.
                +++++++1
                • piopat
                  • 708
                  #368
                  when you press connect is there any text in the log box, if so what is it saying . are you using a null modem cable connected directly to your box and pc or are you also using a usb to serial adaptor . if your just using a null modem cable com1 should work ,if your also using the adaptor try changing com ports and press connect again.
                  • qadam
                    • May 2010
                    Where can I download the latest image file from?
                    • random00345
                      #370
                      easy thanks
                      hi mate thanks very easy gr8
                      • abualferas
                        • May 2010
                        • 18
                        #371
                        Iam using win xp and dm800
                        text = connection prepared power on dream box
                        iam using null cable which work with dm600
                        I used enforcer when flash get massege file to big
                        pleeeease help
                        • piopat
                          • 708
                          #372
                          have a look at this thread mate DM800 NO CA FOUND/FILE TO BIG FIX it may help you with that problem.
                          • abualferas
                            • May 2010
                            • 18
                            #373
                            I read every thread and tried all but problem not solved and just to catch up no ethernet light in the back of the dream
                            please help
                            • piopat
                              • 708
                              #374
                              try unplugging the box and then the router ,unconnect the ethernet cable from the router and reconnect again and do the same with the dreambox . now power up the dreambox and let it boot up ,when it has booted up plug in the router . do you have lights now . you need to try and download the very latest version of dreamup and try flashing again.
                              • abualferas
                                • May 2010
                                • 18
                                #375
                                Thank alot
                                but not working
