CANT CONNECT DREAM BOX TO FLASH FXP OR SIMPLE FTP APP FOR DREAMBOX
  • boothuk
    • 251
    #31
    Try the 10.0.0.1 from DHCP unchecked, it will work I guarantee. Make sure you change your setting on the PC as well as detailed above...
    • boothuk
      • 251
      #32
      Originally posted by staggers
      ok unchecked dhcp rebooted and it worked sorry i am slow in replying i got my 5 year old at me wanting me to play lego batman ...now try tcp/ip bit ?
      Yes!
      If your using Jamesredfern's settings though, make sure you use the same on the Dreambox and the PC. The settings I set out earlier though are entirely adequate if you already inputted them.
      • staggers
        • Apr 2009
        • 149
        #33
        Originally posted by boothuk
        Ofcourse, you will need to change the IP in your FTP software to reflect your above changes.
        Lemme know how it goes pal.
        ok booth tried your settings to ping box recieved 4 so i moved to next step conecting to fxp connection failed
        • boothuk
          • 251
          #34
          FTP should therefore be:
          10.0.0.2
          Port: 21
          User: root
          Password: dreambox
          Have you changed the setting on your TCP/IP to correlate the DB?
          Last edited by boothuk; 15 May, 2009, 15:04. Reason: IP should be 10.0.0.2 not 10.0.0.1 as originally posted.
          • staggers
            • Apr 2009
            • 149
            #35
            i got local area conn or wireless con i changed tcp/ip on local is that right if so connection failed
            • boothuk
              • 251
              #36
              Ok one last time, make sure your settings are as follows:
              Dreambox
              IP Address: 10.0.0.2
              DHCP: Untick
              Subnet: 255.255.255.0
              Type: LAN
              Nameserver: 10.0.0.1
              Gateway: 10.0.0.1
              Your PC should be set as below...
              • staggers
                • Apr 2009
                • 149
                #37
                yep thats what i have done same result m8 connection failed(connection refused) is it time to take it to the local cable guy and pay ?20 for it to be done?not the money that bothers me it looks easy but if i cant get it connected i dont know where else i can go, ive tried flash fxp filezilla and dreambox control centre cheers for your help though
                • boothuk
                  • 251
                  #38
                  Is your port set as 80 on the DB?
                  Other than that, don't have a clue mate, if it's pinging 10.0.0.2 from your computer, they can connect. This issue must be with your FTP client.
                  ftp://10.0.0.2
                  Username: root
                  Password: dreambox
                  You can use Window's explorer, you don't need an FTP program. Type that "ftp://10.0.0.2" in the address bar instead of C:/Documents and blah blah blah...
                  • boothuk
                    • 251
                    #39
                    One last thing to try, on your puter, change the IP address to 10.0.0.1 instead of 10.0.0.2. Maybe thats the issue.
                    • MetalKettle
                      V.I.P.P.T. Member
                      • 797
                      #40
                      The ip adresses on the pc and dream box must be different, but in the same range. If they are identical it will not work.
                      XBMC/KODI Developer
                      • boothuk
                        • 251
                        #41
                        Yep, hopefully he followed that. The IP on his Dreambox should be 10.0.0.2, the IP on his PC should be 10.0.0.1. It's my bad for putting the wrong IP in that pic above...
                        FTP should point to 10.0.0.2.
                        • staggers
                          • Apr 2009
                          • 149
                          #42
                          tx james gonna try it later as ive got to go have a few beers m8 as i am p1ssed off with this will get back to you if it works and tx to you both for your help and patience all the best stags
                          • boothuk
                            • 251
                            #43
                            Phew, think I need a beer to!
                            Hope you get it sorted.
                            • despdan
                              • 544
                              #44
                              Have you checked the firewall options to see if flashfxp is exempt?
                              • staggers
                                • Apr 2009
                                • 149
                                #45
                                flash fxp exempt in firewall dan heres where i am
                                dreambox ip 192.168.0.24 dhcp unchecked
                                netmask 255.255.255.0 enable network checked
                                type lan
                                nameserver 192.168.0.20 port 80
                                gateway 192.168.0.20
                                on my WIRELESS LAPTOP which i have connected to dreambox through crossover cable
                                settings internet protocol version 4(tcp/ipv4)
                                ip 192.168.0.20
                                sm 255.255.255.0
                                dg 192.168.0.24
                                i am using vista with a wireless router dlink di 624+ i have tried all tuts which seem easy enough to follow but i just cant connect dreambox to laptop any ideas cheers stags
