Q5 HD PVR Cable Receiver latest Bouquet with BPL
This topic is closed.
  • Bomchacha
    • Feb 2013
    • 117
    this new channels list can watch EPL or BPL
    https://docs.google.com/file/d/0B4m0...it?usp=sharing
    Updated 27 Aug 2013
    the steps are:
    pls copy it into USB, then input USB on the back of set top box,
    after that, press MENU->SETTINGS-> channel edit-> load channel from USB.
  • DBTraitor
    • Feb 2011
    • 616
    I was just about to ask any member has the latest bouquet for Q5
    Lucky you posted....
    I bought a few of these box too. Good buy
    A wise man learn more from a foolish question than a fool can learn more from a wise answer.
    • uu161
      • May 2012
      • 372
      i guess u bought 5?
      if you like the post use the Like button located bottom right corner of each post
      if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
      • Tyer
        • Aug 2013
        • 5
        Sounds like Q5 is a good box. Too bad the one I had has issue now.
        • micromouse
          • 162
          2222222222222222222222
          • DBTraitor
            • Feb 2011
            • 616
            Originally posted by uu161
            i guess u bought 5?
            Bingo haha Yes I bought 5. ( I got crazy cousins and bro in laws in love with BPL, I no soccer fan)
            No choice, but 4 to 5 piece is very cheap leh. If I buy 1 will cost me around SGD$90
            But out of the 5, 1 of the box got no sound issue, I send back for replacement. Then 1 more is when switch channel too fast and frequent, the sound disappear. Need to restart then everything back to normal.
            Other than that everything is good, can receive BPL also
            • aaronlim
              • Aug 2013
              • 18
              when software version you guys have?
              mine is:
              Software 1.17
              Loader 1.00
              I cannot timer record, do you guys have it?
              • wpjwppwt
                • Mar 2012
                • 28
                Book mark...
                4 pcs lot one around 55usd..
                • wpjwppwt
                  • Mar 2012
                  • 28
                  their xmas present come early ar...
                  • DBTraitor
                    • Feb 2011
                    • 616
                    mine is:
                    Software 1.17
                    Loader 1.00
                    I also dunno which version is mine
                    I never checked, but I got the firmware from seller
                    • aaronlim
                      • Aug 2013
                      • 18
                      Download AppUpgrade_2012_11_20_18250_cn.kzip from Sendspace.com - send big files the easy way
                      can check in the settings under information?
                      Yours can record by timer?
                      I notice its kzip file, how do i update?
                      • DBTraitor
                        • Feb 2011
                        • 616
                        I never try recording
                        Ever since I play with cable receiver from day 1, I have never try recording any program with any box.
                        I just watch as it is.
                        • uu161
                          • May 2012
                          • 372
                          true buy a 800se can buy few of this box ^^
                          hmm sound like QC still not very good.
                          since u sending back why not send the 2nd one switch fast freq issue?
                          me haven't hook 1 thought.
                          • jatrophaseed
                            • 589
                            It Q5 is S10 but cable, good and cheap and easy setting. Master UU, I b back tonite.
                            • micromouse
                              • 162
                              22222222222222222222222
