Q5 HD PVR Cable Receiver latest Bouquet with BPL
This topic is closed.
  • jatrophaseed
    • 589
    #46
    888888888888888888888888888888888888
    • micromouse
      • 162
      #47
      2222222222222222222222222222222
      • fes_786
        • Sep 2009
        • 389
        #48
        sorry to go a bit off topic
        do these boxs come with mgcamd, cccam + newcamd installed???
        would i be able to use one in the uk cable network???
        looks very similar to a s10 / s11 with cable tuner
        • Bomchacha
          • Feb 2013
          • 117
          #49
          some of you experience cannot get SH channels after flashing DBtraitor uploaded firmware. But I tried, my box is still ok.
          Could it be the settings?
          • micromouse
            • 162
            #50
            RRRRRRRRRRRRRRRRR
            • uu161
              • May 2012
              • 372
              #51
              Originally posted by micromouse
              there nothing for u to set unless u know hw to go to the secret menu...
              if u know thru the small vents, ur tuner shld be small n vertical de... tt y u no problem...
              the older batch, tuner is not thsi small small 1... diff f/w...
              Dr. seed posted before old tuner size larger
              if you like the post use the Like button located bottom right corner of each post
              if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
              • micromouse
                • 162
                #52
                DDDDDDDDDDDDDDDDDDD
                • uu161
                  • May 2012
                  • 372
                  #53
                  yayaya... If it ain't broke, don't "fix" it... if not ltr u in a fix... unless u r like me, itchy hand de... wat oso wanna kpo...
                  awaits the new upgrade version, hope to see wifi built in with better UI like better EPG and OSD for channels listing and timer recording...
                  hope my wish list is not too much... hehehe
                  ok wait for Dr.seed and master mm give info then buy and play play
                  • wpjwppwt
                    • Mar 2012
                    • 28
                    #54
                    are u indirectly saying that they are the clones' product engineer? ur wishes.. they will incorporate in the next hardware version..
                    this is awesome..
                    • jatrophaseed
                      • 589
                      #55
                      888888888888888888888888888888888888888888888888
                      • inq
                        • Aug 2013
                        • 4
                        #56
                        hi all for those using q5c are your channel numbers not according to SH ones. i have updated the FW n now there is no image on all SH channels. can someone help me pls
                        • wpjwppwt
                          • Mar 2012
                          • 28
                          #57
                          Originally posted by DBTraitor
                          I was just about to ask any member has the latest bouquet for Q5
                          Lucky you posted....
                          I bought a few of these box too. Good buy
                          hows the box after these few days of usage?
                          any reviews or advice for fellow bros
                          • wpjwppwt
                            • Mar 2012
                            • 28
                            #58
                            hi all..
                            i just receive my Q5.. connect hdmi, RFIN and power..
                            channel listings all in.. but screen says SIGNAL LOST..
                            really hope any kind soul can help! thanks~
                            • Bomchacha
                              • Feb 2013
                              • 117
                              #59
                              I found a channel editor. But not sure how to use it.
                              Just share it here in case any bros like to meddle and explore
                              Q5_CableChanEditor.rar
                              • shidevil
                                • Aug 2013
                                • 84
                                #60
                                Q5 is really good! see next post!
