ireland
  • scuba
    • 198
    #31
    tryed to start it manualy and via telnet...getting:
    Starting hypercam v1.06
    Settings reloaded
    Logs are disabled
    • plasterer
      • 1631
      #32
      Any Cam Changes will need to be 755......Paul
      If your Happy with the Help push the Thanx button
      PAUL
      • Smellyjocks
        • 15
        #33
        Sorry for being dumb, but what is hypercam and where to I get it? Do I only need to upload the zip to var/bin?
        • scuba
          • 198
          #34
          you can get it in 1st post in this thread,i`am still trying to find out how to get it work........
          • plasterer
            • 1631
            #35
            It needs to be unzipped first
            Then do as Despdan says in his post
            For people using Pli Image:
            To add a Soft Cam manually:
            FTP the appropriate files to your box and chmod the files
            Create an empty file with the same name as the Soft Cam, for example "hypercam". Optionally, you can enter the version number of the softcam as text and save it
            Upload this file to /var/etc/plimgr/cams/
            PLi Manager will now detect the new Soft Cam "hypercam", if you entered a version number in your file it will be recognised as such
            Choose the new Soft Cam in the Soft Cam Setup
            PAUL
            • Smellyjocks
              • 15
              #36
              On DK 1.1
              Unzipped files to var/bin
              Opened TuxBox Commander
              Executed the file hypercam_1.06
              Message came up Starting Hypercam..... and 2 other messages
              waited a minute or 2 and keys updated
              Cheers lads!!
              • stan654
                • 48
                #37
                Originally posted by satman
                Shame people wont need to subscribe to your c/s network now
                so you can do that too....f me..orry in a big way so me the way to s**
                • despdan
                  • 544
                  #38
                  Settings reloaded
                  Logs are disabled
                  If you got that message it is working
                  • Saruman0
                    • 40
                    #39
                    Sports, movies and kids are back but some chans are still dead, bbc1, utv and others. Same for you guys?
                    Thanks for the fix!!
                    Hey Saruman0, are you following me or what?
                    • scuba
                      • 198
                      #40
                      thanks despan got it to work,funny dow when go to your cams selection on the box have no cam running?also many channels such as mtvs and kids + some others are not clearing.but anyway finaly we got something to work thanks satman
                      • despdan
                        • 544
                        #41
                        What image you using?
                        try a rescan for missing channels they might have moved them around I believe there are a few HD channels now so they might have shifted a few.
                        • scuba
                          • 198
                          #42
                          using d.k 1.1..will try to rescan and let u know.....
                          • myloyam
                            • Oct 2008
                            #43
                            Finally got me head around this, very straightforward really, but 1 thing I noticed......It would'nt allow me to "execute" the cam, I had to FTP it over a couple of times until it worked.
                            Image : DK V 1.1
                            Using DCC for ftp, Hypercam FTP'd to Var/Bin, Right clicked files, changed attributes to 755 on hypercam.cfg and hypercam_1.06.
                            Left the "keys" attributes at 644.
                            Using DB500 remote, pressed blue, selected "tuxbox commander", navigated to "Var/Bin" scrolled down to "hypercam_1.06", pressed "ok" on remote, pressed left on remote to highlight "ok", pressed exit twice, pressed left again, pressed ok again, exit out to channels.............waited approx 2 mins, changed channel and bingo.................Happy camper !!
                            Now to try getting it working on a dbox2......Anyone got any ideas ??
                            • scuba
                              • 198
                              #44
                              no joy dude still some of them not clearing
                              • despdan
                                • 544
                                #45
                                Any body having trouble getting this working just download it via addons on your box.
                                Have tested hypercam1.01 & this is working if your image doesn't have the latest hypercam1.06
                                For the Pli image just manual copy the files to var/bin folder & chmod them to 755.
                                Then make a file called hypercam & put that in var/etc/plimgr/cams folder. Now you can start it in the softcams options
                                When it starts change the channel & leave for 2mins if it doesn't clear change channel again bingo
                                Also you might have to delete stuff if you var folder if it's nearly full.
                                Also delete keylist.txt & softcam.key in the var keys folder.
