Hypercam N2 Fix How To
does this fix work for anyone with Chorus in ireland.
I am using Digital Kaos v1.1 image I uploaded the 3 files for the irish fix to /var/bin hypercam.cfg, hypercam.keys and kypercan_1.06. I chmod the files to 755. If I try to start ./hypercam_1.06 I ger error "bus error" not sure why this happens ???
I also tried holding down info button on the remote of the 500c until I get EMU manager, in there I selected Evoca enulation is running
I then scan for Choris channels it finds 100+. I go to RTE I can view it but no other encrypted channels. I also rebootedLast edited by quark01; 11 July, 2009, 21:34.Comment
NTL are using NAGRA 2 ;this needs N2 IRL fixdoes this fix work for anyone with Chorus in ireland.
CHORUS are still on NAGRA 1 [cable& terrestrial]
If your on CHORUS cable the nov/dec 08 fix will do
On dk 1.1 use blue button to turn on Mgcam
I don't know what fix is needed for terrestrial but some
member in your area could advise youComment
wat box do u havedoes this fix work for anyone with Chorus in ireland.
are u on cable or terrestrial
and have u ftp'd the fix
give a brief rundown on wat u have done so far
and u will be sorted soonComment
I installed the hypercam fix on my 500t Chxxus mmds (Dk1.1 image)because MGM Movies was not clearing and it worked perfectly , but does anyone know how to make this my default cam as i have to start it manually through Tuxbox Commander anytime I power down?
Cheers
T
Whatever!!Comment
