Hypercam N2 Fix How To
  • Ciaran500
    • 18
    #31
    Can't get this to work on my clean install of a PLI image.
    Created a text file, called it "hypercam", removed the .txt from the name and uploaded it to /var/etc/plimgr/cams and chmod it. Then I have to upload the 3 files in the .tar "hypercam", "hypercam.cfg" and "hypercam.keys". Not sure where to put them so I tried /var/bin and /tmp and chmod them but no cams are appearing in the softcam setup.
    • despdan
      • 544
      #32
      Create a folder called hypercam & put it in the /var/etc/plimgr/cams folder, it will then appear in the softcam menu.
      • Ciaran500
        • 18
        #33
        That didn't work for me. Only default shows for the list of Soft cams available.
        • red devil
          • Oct 2008
          • 690
          #34
          did u reboot and check it then ?
          • Ciaran500
            • 18
            #35
            Yep :/
            Rebooted and tried unplugging it.
            • despdan
              • 544
              #36
              download any cam via the menu then rename it hypercam.
              • Ciaran500
                • 18
                #37
                Downloaded Evocamd and it installed successfully but its not showing in my softcam setup. Same with CCam that was already installed with the image.
                • despdan
                  • 544
                  #38
                  I would flash the box again with pli image & start again, might be a bad flash.
                  • paulybhoy
                    #39
                    Hi Despdan,
                    I'm new to this so bear with me. I have followed all that you said in your post but can't get the Hypercam 1.06 to start up as the default. When I press the blue button on the remote it shows the EMU Manager and Evocamd 2.12 is the only one available.
                    How do I set the Hypercam as the default?
                    How do I access the cam setup? is it with the remote control (what folder)or when the box is connected to my PC?
                    Please help as I am a novice at this and it is driving me crazy..............
                    • wilbirger
                      • 7
                      #40
                      HyperCam on MMDS Ireland
                      Hello,
                      I am new to this but have got my DreamBox 500t on Cho**s MMds.
                      I cant download anything from any damm sites which is annoying.
                      Anyway I have scanned and found my channals but they are scrambled.
                      Anyone know what surely works to clear N2?
                      Was everyone using Hypercam 1.06?
                      • Ansem
                        #41
                        Originally posted by wilbirger
                        Hello,
                        N2 is gone bud, it was only there for a short while
                        It's now and has been for a long time nagra 3
                        I think I replied to another post of yours already
                        Only way that box will work is with cardsharing
