### Digital Kaos v1 Dreambox Image for DM500 C/S/T ###
great work devilfish .. top image .. as always lads can we have some feed back on wot u lot think aswell ..
the PanicButton is a great idea aswell glen - Removes emu, keys, roms, services, bouquets, etc...everything to make it a FTA image. A factory reset or reflash is required if you select this option , that will cheese cable of if they knock the door
Great work guys just logged on seen this so installing it now
! Will post more feedback once i have it going
Thanks for all the hard work team Kaos
<--ronaldo121 added 14 Minutes and 14 Seconds later...-->
My initial impression now i that i have it installed are it is very good seems stable so far which is good. I have been impressed will post further once i have used it for over a day or 2. But initial impression are very good. I like the user interface it is very user friendly.
Good work everyone and thanks for this image.
WelldoneComment
Cant understand why people are having problems with this image, it's the nuts! If you can't FTP, then learn how to do it, it ain't rocket science. Once you can FTP then it's just a case of copying a few files over and bob's your uncle. As it's now a no no to upload anything with keys and roms I suggest people get off their backsides and learn how to use google instead of relying on others for constant spoon feeding. At then end of the day these guys have uploaded a great image for us all, but people still want more? I don't understand. It took me about 3 minutes to flash these image and transfer the necessary files and start the EMU. Come on guys, get up off the sofa and learn how to do something for yourselves.
Rant over...
Keep up the good work guys!
JPIF YOU LIKE THIS POST PLEASE HIT THE THANKS BUTTONComment
There's a good guide here for connecting your dreambox to your PC.
Accidently Pressed the panic button Whoops!!
Sorted it out. Phew.
Its got alot on it. Brilliant Image though
Is it still possible to use Ngrab Recording or not?
Cant find record button or do you record from web interface onto a mounted folder.ORYComment
just press the epg (press ok and the info the multi epg) and choose from there and press yellow and the box will come on like the image below change settings it u have to . then green the start timed recordingAttached Filesany information provided is for educational/experimental purposes only.Comment
listen mr smartypants,Cant understand why people are having problems with this image, it's the nuts! If you can't FTP, then learn how to do it, it ain't rocket science. Once you can FTP then it's just a case of copying a few files over and bob's your uncle. As it's now a no no to upload anything with keys and roms I suggest people get off their backsides and learn how to use google instead of relying on others for constant spoon feeding. At then end of the day these guys have uploaded a great image for us all, but people still want more? I don't understand. It took me about 3 minutes to flash these image and transfer the necessary files and start the EMU. Come on guys, get up off the sofa and learn how to do something for yourselves.
Rant over...
JP
, go buy a brand new pc (that wont have a serial port, like mines) and has windows vista installed, then come back and tell my you ftp'd, and flashed box's and modems etc, then i will take you seriously, and whats the matter with spoonfeeding the people who need that kind of help anyways, ive been into modems and digy box's for years now, but there are some people who can hardly turn on a pc letalone do box's, so explain to me just how easy these people would find these tasks ?? and like ive says before, ive never been able to ftp, just one of those things, and with this brand new pc it looks like nuffin is possible, just a few words.
rant over.
Guide To FTP
We all Know how you feel Thomson
Hope this helps pick it from DW sometime ago really really helpful
If you follow it you may still require a bit of practice you need to get your
head around NETWORK IP address's and your half way there.
Hope it helps... PS this is a good place to start http://portforward.com/networking/staticip.htmAttached FilesLast edited by Gueststar; 6 June, 2008, 21:16.ORYComment
just forget it man, like i said 100 times before, ive always had hassle ftp'n , so iam done with even trying, it pizzed me off so much in the past i dont even try now, so unless someone can help me with the thing already done i guess theres not much point in me posting again, thanks
<--Thomson added 4 Minutes and 18 Seconds later...-->
iam just going back to my old image that another user in the forum gave me, all setup and channels in order , the lot, sorted
, this is too much hassle.
well lm not going to spoon feed u m8 , but l will spoon the bird in your avatar
wot was wrong with the back up l sent u ?any information provided is for educational/experimental purposes only.Comment
smirnoff, it didnt work, tried everything, just got blank screen on the pay channels, done everything as directed, still blanko.
And with regards to spoonfeeding, iam one of the people who are all for helping people fully that dont have a clue and need a quick fix, some people just cant do stuff, simple as that, not saying i cant, but some just cant take stuff in, ive been a member of forums as you know in the past and for years n years i have helped people a few times with things, more people have helped me though than me them, but you wont find a single post anywhere on forums where i slate people for wanting spoonfed as youz keep saying, its either a case of you want to help, then help, if not then dont, simple as that.
I'll put a bet on that ive been a member on certain forums for longer than you and probably nearly every other user on this site, not that that has anything to do with it, but just stating ive seen it, heard it, and done it all, know what i mean ?Comment
then l cant for the life of me work out why u cant connect to a router ? theres newbies doing it . l have vista and no serial post ? u have to be missing something m8 .. if u looked there was a
in there .
iam
, too, just making a point though about the spoonfeed stuff, i dont think its perticularly nice to treat people that way, i know i wouldnt.
