800C just arrived.
  • maddogs
    • 40
    #16
    I have one of these on order too so am reading this with interest..
    • osborne82
      Dreambox Guru
      • 133
      #17
      Originally posted by Bonesy
      And how do we go about diong this so we can release image for everyone else here in uk?
      well first you woul have to look at the diff for enigma1 (it should be in dev section ) make some sense of it then open up enigma 2 and see how to apply. The problem will be that enigma1 sources are c++ and enigma2 is python and as theres not much call for e2 cable not many teams will want to look at this problem
      its doable though
      cheers
      osborne82
      • Bonesy
        • 655
        #18
        its doable though
        cheers
        osborne82
        Im no programmer so thats not looking good as I wouldnt know where to start.
        My 500gb hard drive just arrvied just now...so going to put that in this morning and see how that goes.
        There is also options to save epg on hard drvie and different epg options, so I wonder if possible for box to grab epg from net andshow that instead. Shall inform of the progress.
        When done I'll make my image with ALL files included etc... availible to anyone who wants it, hopefully save you some headache.
        • osborne82
          Dreambox Guru
          • 133
          #19
          try the loadepg tool its for sat but im sure theres a option to have it download from radiotimes website (look at loadepg.conf ) prob wont get all cable channels but id imagin it'l get most
          cheers
          osborne82
          • Bonesy
            • 655
            #20
            thanks Osborne.
            Ok, got 500gb installed and it appears to be spinning when utrned on. But in natblo blue panel setup, hard drive wizard, it doesnt see the hardware.
            Should I format it firt on my pc or???
            • Bonesy
              • 655
              #21
              Ok, Ive formated it to ntfs format, but still the dreambox 800 cant see it.
              I have just reflashed the unit with gemini4.4 in device manager, still doesnt see it.
              Anyone any ideas???
              • Gazmann
                • 70
                #22
                good man thanks
                • on_the_jazz
                  • 557
                  #23
                  Anyone any ideas???
                  Try formatting in pc as FAT or FAT32. Then put in box.
                  • u6cah
                    • 7
                    #24
                    Well this is my experience, I had a genuine DM800 which I have purchased a cable tuner for and this is what I have done and am pretty happy with it.
                    Downloaded the latest PLI Jade image for DM800.
                    Scanned for channels
                    downloaded mgcamd and uploaded roms.
                    Everything started to clear and I am happy with the speed of the EPG seems fine however it only downloads the next 8 hours so this may not be what you are after. Now and next is fine and on all channels.
                    Will keep you updated as I keep on playing around with this config
                    • Bonesy
                      • 655
                      #25
                      ok I've formated it to fat32 and also to linux ext3. None of the image see it. I have elimated the possibilties its the cables.
                      Image tryed on:
                      pli-enigma2-jade3-dm800-20090914-6654
                      NabiloBlackHole_DM800_06_s69.nfi
                      Gemini-4.4-BL72-DM800
                      THe drive itself is a Western Digital 500GB model:WD5000BEVT - I know others have the same drive working in their dm800S
                      So, after 10hours of trial and testing, I have failed to get the hard drive to be reconised by the dreambox so am at a lost as to what to try now....Im giving up for the night and if anyone comes up with a plausible way to get it to work, shall resign myself to failing.
                      • Swiftie
                        • 141
                        #26
                        Image tryed on:
                        Have you got any other HD that are a sata you can use to test? They don't have to be 2.5
                        E Pluribus Unum
                        From the one to whom much has been entrusted, even more will be demanded!
                        If you have received help from this post, press the "THANKS" button to show your appreciation.
                        • osborne82
                          Dreambox Guru
                          • 133
                          #27
                          Image tryed on:
                          it should be ext3 for linux have u any other mounts set up ?
                          telnet in and try
                          df
                          whats the output ?
                          cheers
                          osborne82
                          • Bonesy
                            • 655
                            #28
                            telnet in and try
                            df
                            whats the output ?
                            cheers
                            osborne82
                            output with df command is:
                            root@dm800:~# df
                            Filesystem 1k-blocks Used Available Use% Mounted on
                            /dev/mtdblock3 61440 37920 23520 62% /
                            /dev/mtdblock/2 3840 2444 1396 64% /boot
                            tmpfs 78836 36 78800 0% /var
                            tmpfs 78836 12 78824 0% /tmp
                            currrent image is gemini 4.4, drive is formated to linux ext3 on sata connection
                            Thanks for helping me Ozzy...I hate to giveup on anyhing and yesterday just drained me.
                            • Sicilian
                              • 168
                              #29
                              Try an older image to format the HDD, found that some of the newer images are a bit buggy when it comes to formatting the HDD or CF card.
                              D I S C L A I M E R My right to post information is protected under the rights for freedom act. In all instances, information discussed here on my posts are either hypothetical in nature, out of general curiosity, common knowledge, public knowledge, or role-play. Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader. I am not responsible for what you do with it.
                              • Bonesy
                                • 655
                                #30
                                The problem isnt formating, its getting the image to see the drive is attached first
