DM800 clone setup help a veteran please
  • saayinla
    • 162
    #31
    Originally posted by Bonesy
    I havent seen bootloader 75 image anywhere
    I found a few when Scouring the net they all have .ipk exntension and I read that you instal then through the plugin menu. Not sure how true that is.
    • loady
      • Oct 2008
      • 72
      #32
      Then in that case...use a bootloader to get you up and running then use the ipk package via the menu....though im not sure if it will let you browse for it locally, i think it has to come to the box via a server of some sort. To be honest i have not heard of any reasons why you should use it
      • loady
        • Oct 2008
        • 72
        #33
        Ok just checked:
        HD channels I have are:
        FX HD
        ESPN HD
        Channel 4 HD
        BBC HD
        MTV HD
        Nat Geo HD details below:
        transponder 5
        network ID 49
        namespace -65536
        Feq 723000
        other parameters :6887000:2:3:3:0
        Package 57A
        Service ID 502
        Thats what i have, though i dont have a picture on Nat Geo, also i dont see a discovery channel in that line up or was that meant to mean the Nat geo channell ?
        • Bonesy
          • 655
          #34
          yerp nat geo my mistake.
          Setup: 2x Dreambox 800HD | 3x Dm500S on Motorised dish Setup
          • loady
            • Oct 2008
            • 72
            #35
            No problem...good to go then all bar ITV HD...not sure how to go about getting that. Whilst i thank you for your working image i thought it best to build my own from scratch to give me an idea of exactly what needs to be added and what goes where, with regard to the key and roms are these the same as the DM500c and what about the cams ? where do i get them from and which folder do they go in and what cams should i be using...thanks
            • loady
              • Oct 2008
              • 72
              #36
              UPDATE: Well i tried the nabilo sat BHv12 image and used bootloader 72r1 straight after..gotta say im very impressed and i think its a lot better than the gemini i was using, found my HDD straight away and initialised it for use without fuss or hassle, i am really enjoying using it at the moment, just need to get the decrypted channels going.
              • saayinla
                • 162
                #37
                Are you still using the cable turner or Sat? Is there any easier way to clear the current list of channels left on bonesy's scan other than to manually add them to favourites and delete from there? because I currently have 2-3 listing for each channel and its driving me nuts..
                • Bonesy
                  • 655
                  #38
                  Originally posted by saayinla
                  You have most Certainly been very helpful, I was able to get another copy on the Sat Dreambox section of this forum. I have another question for you, My box is now up and running however i had to do a scan in my own area and now I have 2-3 listing of the same channel, your existing listing before the scan and the channels I found in my own scan. What I want to do now is delete all existing services and do a fresh scan. I havent been successful at all with this.
                  I use dreamboxedit software for sorting all my channels..itsin downloads section.
                  • loady
                    • Oct 2008
                    • 72
                    #39
                    I only have a cable tuner in it, you should be able to set it to clear channels before you perform the scan.
                    • saayinla
                      • 162
                      #40
                      After wasting a couple of hours I was able to finally fugure it out. Thanks however, I only get 5 hd channels in my scan however i pick up bbc hd on my 500c but not on my 800hd... i ll keep rescanning until i find it.
                      Channels i have are:
                      Channel 4 HD
                      FX HD
                      ESPN HD
                      NAT GEO HD
                      MTVN HD.
                      • loady
                        • Oct 2008
                        • 72
                        #41
                        As you have a dm500c it should easy enough to find a freqeuncy to start your scan, I'm lucky as I know mine to be 118, goto your dm500c and get the BBC HD channel up, I'm not sure what the button sequence is but you need to looks at the stream info for that channell, suppose you could call it properties, that should tell you what the freqency of that channell is and you can enter that into your manual scan on the dm800c. I have found as have you that developmentfor these is in the early stages for us in the uk, hence we don't have a cables.XML we can use or pre configured area scan or, as you will soon find out, a working epg.
                        • westkill
                          • 2378
                          #42
                          when your on about stream info for a certain channel on the dm500c is put it on the channel you want then goto menu>information>services this will give you the frequency/transponder for that channel i think
                          • saayinla
                            • 162
                            #43
                            Thanks guys I have done it again and Now Hurray I have all 7 HD channels Live and Running!
                            BBC HD
                            CHANNEL 4HD
                            ESPN HD
                            FX HD
                            LIVING HD
                            MTVN HD
                            NAT GEO
                            And also I find the dreambox edit software very good, it works like magic. All I need to do now is sort out the bouquet and then take a back up.
                            • Bonesy
                              • 655
                              #44
                              BBC HD
                              CHANNEL 4HD
                              ESPN HD
                              FX HD
                              LIVING HD
                              MTVN HD
                              NAT GEO
                              glad your sorted..see easy when you know how eh?
                              • saayinla
                                • 162
                                #45
                                On another Note, the dreambox dosent seem to shut down completely as the dvi output is kind of still active. The problem is I use hdmi switch as my tv has only one hdmi port. and what happens with the switch is that the last device switched on connected to the switch is the one that is output to the TV however in the case of the DM800hd, even when its switch off, Its still not letting my PS3 for example connect through the port, currently what am doing is to take the power plug out of the 800hd, but i cannot be doing this all the time, and to be honest I got this box basically due to the HD channels and I wouldnt want to use scart plug, would there be anyting in settings to completely switch off the dvi port when the box is switched off.
