I'm not saying you haven't but some people don't read the whole post and jump the gun then find out the solution has been there all the time, so just to be sure have you followed this m8 http://www.digital-kaos.co.uk/forums...41/#post360310
Fix: No CA Error
The panel has quite simply found 'no evidence' in support of allegations of 'exceptional levels of drunkenness, ticketlessness or violence among Liverpool fans' and 'no evidence that fans had conspired to arrive late at the stadium' and 'no evidence that they stole from the dead and dying'. -
Thanks for your patience,I'm not saying you haven't but some people don't read the whole post and jump the gun then find out the solution has been there all the time, so just to be sure have you followed this m8 http://www.digital-kaos.co.uk/forums...41/#post360310
I tried this again and again with the same result!
Now for the second sollution
1) Connect broken dreambox DM600/DM800
2) Open dreamup, press connect.
3) When you see second loader error popup, just press ok.
4) Open http://www.gsmsweden.com/forhike/sat...stage_pack.rar
5) Drag DM800_repair in front of dreamup, and press dream multimedia logo.
6) Now press the greyed Flash button, and chose firmware.
7) The flash progress will probably hang, its OK.
8) Open dreamup again, connect the broken box, press connect.
9) If all went ok, you can now flash box again, (Use only serial
communication)
When I run step 9, I get:
No CA found by 2nd stage loader.Comment
HI i had this problem bought this [ame=http://www.amazon.co.uk/gp/product/B00077DJIQ/ref=cm_cr_mts_prod_img]USB to RS232 - USB Converter Cable: Amazon.co.uk: Computers & Accessories[/ame] the driver is here [ame=http://www.prolific.com.tw/eng/downloads.asp?ID=31]Welcome to Prolific[/ame]
works fine in vista tells you which com port it was installed on just remember you need to select the right com port of you serial device in dreamup or your dreambox wont show up.
You also need a DB9 Female to Female Gender Changer like this [ame=http://www.amazon.co.uk/DB9-Female-Gender-Changer/dp/B000Q8FDAS/ref=sr_1_2?s=computers&ie=UTF8&qid=1288985272&sr=1-2]DB9 Female to Female Gender Changer: Amazon.co.uk: Computers & Accessories[/ame]Comment
This method worked for me:
the link for the no CA fix is down - does anyone have this file available?
I had some serious trouble trying to get my dm800 running again with these no ca error & file to big errors.
I had upgraded my sim card to ferrari using the 'free-ferrari-upgrade-1-1.nfi'. This had been working fine for a few weeks, until I flashed the wrong image this is when I first got the 'no ca error'.
I tried flashing all sorts of images and bootloaders but the 'no ca error' wouldnt go away.
In the end I connected via serial and lan cable. Ticked use network in dreamup and flashed the 'free-ferrari-upgrade-1-1.nfi' back to my box, by entering the ip address on the screen of my box and displayed in dreamup int my web browser. At first it hung on dhcp while booting up. i removed the network cable and rebooted. This time it booted up properly, I ran the ferrari upgrade tool from the plugins menu. It said upgrade successful. I now rebooted and could flash a new ferrari image again. Maybe this is of use to somebodyLast edited by rondiamond; 17 February, 2011, 00:37.Comment
when i am opining this link http://www.gsmsweden.com/forhike/sat...stage_pack.rar is telling me ERROR SIDE NOT FOUND there is another link please thanksComment
2ND STAGE BOOTLOADER AND FILESwhen i am opining this link http://www.gsmsweden.com/forhike/sat...stage_pack.rar is telling me ERROR SIDE NOT FOUND there is another link please thanks
2nd_stage_pack.rarComment
