Fix: No CA Error
  • almuluca
    • May 2012
    Hello I've a DM800 SE clone ,I 've put an usb pen in my dm and show me in display R01 no CA FOUND !What I need for recovery??I don't know SSL ,SIM version ,NOTHING!!Only I know that is ALLRUSSIAN image charged from factory!!
    Someone can me help me???
    THanks a LOT
    BYE
    • te96
      • May 2012
      Having the same issue.
      Tried to update my 800HD with a patched image for SIM 2.01 and got NO CA found!
      • meinbaruh
        • May 2012
        Hi
        Looking for a solution for DB800 HD PVR
        Same problem with second stage like everyone else,
        does the attached file on page 6 work for my model also?
        • Moksan22
          • Jul 2012
          • 19
          #94
          Easier fix:for dm800hd SE ,at the back of the box there is this mini flash button.first switch off the power using switch at the back of box.then press the mini flash button and hold it.then power on with the switch with the mini flash still pressed.then in the LCD u able see the STOP and then the IP address.
          • ernestchee
            • Jul 2012
            #95
            my dm800HD SIM2 is dead
            Hi people.
            I have tried all ways to fix the NO CA FOUND error but it still doesn't work.
            My usb to rs232 converter can't detect the DM800HD . I am using the optiflasher.
            It gets stuck at the "Power On DB Device".
            Is it bricked for GOOD?
            Any kind souls can advise? Thank you.
            • DBTraitor
              • Feb 2011
              • 616
              #96
              Maybe its not compatible or you didn't use a null modem cable, thats why cannot detect
              So is your usb adapter able to detect other box?
              A wise man learn more from a foolish question than a fool can learn more from a wise answer.
              • ernestchee
                • Jul 2012
                #97
                I don't have other boxes to test.
                Is it also because I am using Windows 7?
                Will windows XP work in this case?
                I am using the USB to RS 232 converter with the FT232L chipset.
                Is this cable a null modem compatible cable? Or should I specifically get one which has the null modem internal pin wiring?
                Thank you.
                Edit: Got it working! Used the null modem cable I bought today and plugged it into my COM 1 port on my PC. One click does it with optiflasher! Thanks!!
                • jhojo
                  • Sep 2012
                  A friend of mine has a DM800HD Clone, I have no idea what sim is in it, but he changed it skin in the software and the thing crashed. now it wont boot just says error in display, i am not familiar with clones, but hooked it up on patched dreamup after some googling. But I get stuck on File too big error. I understand I need a patched image but I am thinking I might have the wrong one???
                  • DBTraitor
                    • Feb 2011
                    • 616
                    #99
                    use web browser flashing
                    reflash your image
                    • adrianc1982
                      • Jun 2011
                      my dm800 is not responding to dreamup with com port, i plug a dm500 and it works, ive tried dreamup patched and several others but there seems to be no serial comunication with my dm800.
                      I repeat my serial is working since with dreamup 1.3.3.0 it detects my dm500 and the dreamup for dm800 patched is not working, any ideas?
                      • DBTraitor
                        • Feb 2011
                        • 616
                        #101
                        Use web browser flashing method
                        • akakeno
                          • Jan 2013
                          So I've read all the instructions, I have my Null Modem and now I need to know what image to use for my 800HD clone cause the last one clearly didnt work! Can you help?
                          • deffc0n
                            • Aug 2009
                            • 894
                            #103
                            Use normal image for your sim card.
                            • ashley1
                              • Dec 2012
                              #104
                              dreambox 800 hd pvr-clone
                              Hi all I also had a problem with mine dm 800 hd clone /ca error/ and after a few sleepless nights I found this software and now everything is OK. I hope to help people in need
                              • vta
                                • Jan 2013
                                Do anyone know a method to identify the sim card version?
