NO CA FOUND/FILE TO BIG FIX
  • dlegrand
    • Jan 2013
    same problem, thanks
    • reddy
      • 37
      #182
      same here, tried flashing for a friend and it shows this fault after flash and i'm sure the image is working as it was a backup from my working SE.
      From what i understand, My friend claims that the clone that he just bought came with original Sim, so can use the original image from Dreambox. ( Not sure how true is that??.) Could this be the issue? Not compatible with images suitable only for clones??. i have returned the box to my friend, so cannot test it out now..
      • uu161
        • May 2012
        • 372
        #183
        ur friend are right there is A8P sim original clone sim in market for DM500HD and DM800SE
        already out for mths and flashing any original image only
        clone image will not work on A8P sim
        if you like the post use the Like button located bottom right corner of each post
        if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
        • reddy
          • 37
          #184
          Alamak, like that jialet, so must now clear the CA fault first , then download original images only to flash in , then put in bouquet.
          Then only will be solved right?. Susah lah!!!... Dunno why people want original for??...
          • uu161
            • May 2012
            • 372
            #185
            Yes and original image will be better no more green screen issue doing any update
            • reddy
              • 37
              #186
              Ok, thanks for advise..
              Try to look for original images first.
              I hope the web browser methods and dreambox edit do not have any other restrictions surprises later..
              Haha!!
              • matp123
                • Jan 2013
                #187
                DM800 HD PVR Will Not Flash
                Hi All
                im losing the will to live. ive trawled through the forum's and im failrly sure ive gone though every page on the internet to no avail
                due to stupidity on my part i now have to reflash my dreambox.
                i have tried various versions of Dreamup and get as far as flashing the memory. After an hour or so it just sits there saying box is flashing from memory,
                when using the 3.2.4 image. ive have tried various others and either get the same message or " Invalid Image "
                i get no " all complete " or " ok" messages. i even left it over night. when i disconnect the null modem connection and restart the box it goes straigh back to No CA Found.
                im now out of ideas.
                Any help much appreciated
                • mctouf
                  • Jan 2013
                  thank you
                  I will try this
                  • yusufak
                    • Jul 2012
                    cant seem to find a solution Im stuck with it
                    • halim23
                      • Feb 2013
                      here the same problem. Dreamup is not working...
                      • fayroumf
                        • Mar 2013
                        sim A8P
                        what about the dm800se hd come with sim a8p?
                        is it same as sim 2.0
                        • niels4545
                          thx helped a lot!
                          • melvillecook
                            • Mar 2013
                            Hi there, I have a CLONE Dreambox DM800 HD PVR and it has the SIM210, when I turn it on ALL I get on the screen is DREAM MULTIMEDIA -> ERROR! ERR01 NO CA FOUND, I have downloaded and tried dreamup, I have tried to flash it and when I connect the cable and link it to my PC and try and flash it, it says FILE TO BIG. PLEASE HELP, thanks
                            • Decoder
                              • 46
                              #194
                              Hi melvillecook Think your problem is you've flashed with wrong image (err01 No CA Found) what I have found is make sure you have box connected to internet, computer hard wired (reversed/crossed cable) run latest Dreamup, get box IP address, open browser on computer and then put IP address into address bar and when found (the box) you can Flash correct software. Are you sure 800HD has SIM210 as my 800HD has SIM2.01 and my 800HD se has SIM2.10? Hope this helps and you get it sorted, best wishes
                              • Decoder
                                • 46
                                #195
                                Hi fayroumf No mate they are not the same SIM. With the A8P SIM you can ONLY use genuine software and the SIM2.10 is for CLONE software ONLY
