NO CA FOUND/FILE TO BIG FIX
  • aristote12000
    • Nov 2011
    FILE To BIG!
    Help me
    My 800hd Is out
    When open Dreamup patched and connect I have this message:
    FILE To BIG
    • azir2981
      • Aug 2011
      Is it working for all BL59, BL 62 ETC...
      • Ome Merde
        • Nov 2011
        #138
        I've got the same problem over here
        no matter what I try, the error is back after every reboot
        cable is 100% ok
        if I bootup (for the use with dreamup), check "use network" I can access the webif. I can flash an (old) image but it hangs at aprox. 45.70%
        I've been busy for 5 days now, I'm fed up with it
        regards,
        merDe
        • Ome Merde
          • Nov 2011
          #139
          just fixed it !!
          what I did (in my case, old dm800hd (sim1(?))
          * download dreamup and secondstage-dm800-69.rar which can be found at the following link : http://www.digital-kaos.co.uk/forums...8/index11.html
          * connect the box with the crosslinked serial cable and network
          * prepare the connection, switch on the box and wait for the error
          * a bootloader was uploaded
          * close dreamup, power-off the box
          * download optiflash 1.0.6 (google) and make a serial connection
          * choose "write bootloader", click "do job", follow instructions
          * networkcable must be attached, type the ip-address
          * choose in the following screen "secondstage-dm800-69.nfi" (downloaded before)
          * afther finished, poweroff box, hold button on the box, poweron
          * oi, dhcp is working again
          * open browser (IE8 in my case), navigate to image to flash. I choose an old ssl69 image, just for testing. GP2 with ssl69 worked for me, can be downloaded at Multiupload.com - upload your files to multiple file hosting sites!
          * flash it by the webinterface
          * reboot after finishing and grab yourself a cold one
          tomorrow I'll try to update to a more recent image. my five days of agony are over so far
          merDe
          • mete61
            • Nov 2011
            clone dm800
            whats the new dreamup 1334 or is dare a new
            • Zepic
              • Dec 2011
              Which version of dreamup do you need?
              • Mirfa
                • Dec 2011
                Can anybody help me with this error msg "Error1: no ca found? please
                • leppard
                  flash bootloader then it will be working
                  • jokkeri77
                    • Dec 2011
                    Originally posted by Ome Merde
                    just fixed it !!
                    merDe
                    Thanks so much for this!!! It helped me revive my DM800 (it says SIM 2.01 at the back).
                    I had the CA not found error, and couldn't get various versions of Dreamup to work (the patched version said file too big, and 1.3.3.8 got stuck at "upload complete - waiting for acknowledge".
                    I tried the "Repair" option in the Optiflash tool, but that didn't work (no CA found error after reboot). But the "Write Boot-loader" option in Optiflash has become my hero, was able to flash the SSL-84b from another site, and after reboot, my old image booted fine (btw also the GP2 5.1 bl69). I think I will need to flash another image at some point, but I'm too tired now after ages of troubleshooting.
                    Hope this helps someone.
                    • mrwok
                      • Jan 2012
                      #145
                      no ca found dm800se ferrari
                      Originally posted by yassinov
                      Too much Steps on the classic method !
                      OptiFlasher make it easy for you !
                      -Run OptiFlasher
                      -Click Advanced
                      -Select Port
                      -Select Model
                      -Write Bootloader or Repair NO CA Found
                      -Do Job
                      regards , yassinov
                      i try this one lot of time no START 1.8 had no dm800se ferrari suport "NO ca FOUNDDDDDDDDDD"inside
                      is there on this planet ONE person who explane THE BIG file bug and lot of people have the same shit!!!!!!!!!!!
                      dm800 is no problem ca no found because rs232 cable is hard flash(you know) and usb is soft shit.
                      Is the trick "pc-->rs232 cable--adapter-->mini usb-->dm800se?????????????"Make test please i have not this cable.
                      THE person who makes my dm800se ferrari alive is "The Besttttttttt"
                      • mrwok
                        • Jan 2012
                        #146
                        no ca FOUND dm800se
                        good job only works with dm800 ----->Dm800se have mini usb no ca found is then hang on BIG FILE SHIT ssl62,ssl69,ssl enz is too BIG is there one people on this planet its TIME to MAKE this BIG bUG for lot of people FINished
                        TANKS
                        Originally posted by t1elm
                        good job fixed my no ca!!
                        • bilon
                          • Jan 2012
                          Hello, I have a problem with my dreambox 800pro with sim210 (clone)
                          when i try flash my dreambox, dreamup show me message that file is too big, i try to different bootloaders and ssl and still same message file to big, what am I doing wrong??
                          Maybe someone can tell me what i need to use, second stage loader or bootloader and which one??
                          • cassano82
                            • Jan 2012
                            Tnx...I hope to solve with this method ... I have the Dreambox Second Stage Loader BUILD # 59
                            • mide2008
                              • Jan 2012
                              i have a clone dm800 hd. Pls how can i determine the sim number on my dm. On opening it up i only saw a plain white sim nothing on it.
                              • checkersceltic
                                • Jan 2012
                                #150
                                file to big
                                hi guys, i have the same problem.
                                oled display reads no c a found.
                                so far i have used dreamup then enforcer.
                                so far i have managed to highlight the flash button but when i try to flash all i get is file to big!!!!!!!
                                please can anybody help its now been 2 days and about 100 posts read but still cant seem to get a solution
                                help help help
                                all the best
