NO CA FOUND/FILE TO BIG FIX
  • Arraysys
    • 173
    #76
    Originally posted by dave2014
    This problem really stressing me :-( I have the err01 No CA Found)
    I have managed to flash a new image several times and still the error occurs, I have also flashed new bootloader and again error occurs, I think I have tried every tut available. Dont know if it makes a difference but this is a new clone I bought with latest M tuner to replace previous dm800 with glitching hd channels, the older dm800 always flashed fine first time
    Are you talking about the new DM800PRO Satellite Receiver which come the Tuner: HIG003 REV:M (HD channel 8PSK/QPSK Symbol rate 1-45M/S)?
    For "err01 No CA Found" most likely related to the image software that you are using to flash. Can I ask whether where you get the software image? Was the software being patched for CLONE dm800? Or have you ever try to patch after flashing with original software image.
    • dave2014
      • Oct 2008
      • 68
      #77
      Yes it is dm800 satalite with the tuner you refer to Its a clone, i got it from dvbseller), i am not sure if it is a pro as it was just sent out as a direct relacement for my other dm800 which glitched on hd channels. I get my images from dm800sim2.com and yes they are pre patched (I think). I was unsure where to get original images. I just used the images I used on my previous dm800 as they flashed easily on that one with no problems, can pre patched images not be used now as I? This is the image I prefer to use and which I had on previous dm800 UNOFFICIAL DREAM ELITE V.133DV3 PHOENIX EDITION. Can you reccommend a solution
      Thanks for your reply
      • dave2014
        • Oct 2008
        • 68
        #78
        I have now managed to get it to boot into an image using bl69, if i try any other bootloader I get the no ca error again. Image boots up but when it gets to where the tuner config page should be it gets "system error hardware could not be verified", Please any ideas anyone, i will move this to the correct satallite section, sorry
        • Bonesy
          • 655
          #79
          "system error hardware could not be verified", related to the image you putting on have the genuine dreambox plugin installed where it checks if the dreambox is a clone or not.
          • dave2014
            • Oct 2008
            • 68
            #80
            I have managed to get box working now with another image, but still my box will not boot up with anything other then bl69 even though originally it had bl76. As for the Genuine Dreambox plugin, this always says "security service not running" even though box is now working, obviously something is a miss or corrupt in my box, i just do not know what :-(
            • Persian
              • Feb 2011
              please help to me i have problem file to big!!
              i use Enforcer.exe and but not ok!
              • dave2014
                • Oct 2008
                • 68
                #82
                When you power up your dreambox and dreamup starts uploading the basic bootloader let the blue progress bar get atleast half way and then press flash, should let you flash whatever image/bootloader you want then. Hope that helps
                • mus2007
                  • Feb 2011
                  FILE TO BIG
                  my dreambox 800 hd dead. no display, no ip, when i try to flash box is given me FILE TO BIG FIX error. plz help
                  • dreamteam666
                    • Feb 2011
                    #84
                    Thank you but still file to big error I need help thnx
                    • dreamteam666
                      • Feb 2011
                      #85
                      someone can Help pls thank you
                        make sure your flashing the correct bootloader in the image for your box.
                        • beebee31
                          • Feb 2011
                          #87
                          hi all
                          Originally posted by halau
                          Ok with help from Superman at supersatshop this is what i done and it worked
                          connect dreambox to router
                          use crossover cable connect router to laptop
                          open dreamup
                          connect null modem
                          connect power to dreambox while holding silver power button till dreamup has fully loaded
                          find IP of box (i used dcc) mine edded up being a very strang 192.168.1.6
                          put this in dreamup
                          open enforcer
                          load image and flash
                          I have found the Gemini images are useless as i done all above and it failed to boot up again so best to use another i have nabilosat and all is fine here
                          Again thanks Superman for your hours of help
                          I wish to buy the dm800, and who should i get from and must 1 do anything to it when it arrive in singapore?
                          • rondiamond
                            • 4
                            #88
                            I had some serious trouble trying to get my dm800 running again with these no ca error & file to big errors.
                            I had upgraded my sim card to ferrari using the 'free-ferrari-upgrade-1-1.nfi'. This had been working fine for a few weeks, until I flashed the wrong image this is when I first got the 'no ca error'.
                            I tried flashing all sorts of images and bootloaders but the 'no ca error' wouldnt go away.
                            In the end I connected via serial and lan cable. Ticked use network in dreamup and flashed the 'free-ferrari-upgrade-1-1.nfi' back to my box, by entering the ip address on the screen of my box and displayed in dreamup int my web browser. At first it hung on dhcp while booting up. i removed the network cable and rebooted. This time it booted up properly, I ran the ferrari upgrade tool from the plugins menu. It said upgrade successful. I now rebooted and could flash a new ferrari image again. Maybe this is of use to somebody
                            • diviqm
                              • Feb 2010
                              #89
                              it works
                              yesterday i was have success with dead dm800 clone SIM2.01
                              i use SSL76D-20101219.nfi loader and then without reseting you can load image witch you want.Use second stage pack and full cros RS232 cable.
                              Both method work well.
                              The problem with error NO CA found and FILE IS TOO BIG make me crazy all three days .
                              THE BIG PROBLEM of clone DM800 is simcard holder - there is no good contact with sim.I was press and hold on the simholder and then start dreamup - all errors is go on.Card slot is loose and can not pressed well to contact pins.
                              • ultrakiasu
                                • 128
                                #90
                                I am assisting my colleague to get his clone DM800HD to work.
                                Very weird behaviour compared to the other DM800HD i had recovered earlier.
                                This time, the DreamUP does not response, no detection, no dialog box pop up complaining "No CA..."
                                Was told he had use DreamUp to replace the shipped TGP firmware with DreamElite sim2.01, and dont like the layout, and flashed some firmware downloaded from OpenPLI, and got stucked since.
                                Tried the DMM logo clicking fix, Tried Enforcer..
                                Cant get even an IP at all..
                                I am totally lost.. anyone able provide a solution?
                                Thanks in Advance
