Crossed lan cable and working rs232 cable connected.
Using universal dreamup 1.3.3.4 with http and telnet
Status, Box is in networked http mode.
Error No CA found by 2nd stage loader etcetera
Log,
box type DM800
Enabled recovery of bad sectors
No CA found by 2nd stage loader....
Result, have an ip 10.0.0.2, gateway 10.0.0.112 from dreamup and can ping it, have telnet / tftpd and http web with flash uploading.
No ftp service active.
However, web flash 100% and still no go, dreambox display only says error.
Terminal say nand-set-pen, start flashing..., finished.
Also strange, with telnet his advanced setup util, settings are saved because i can see the action in the terminal but it's gone by a dbox restart.
Unfortunately i am not able to use serial connexion on my DM 800. I tried a lot of Dreamup version without any succes.
Who can give me the right oinout for null modem working with DM 800
Thanks a lot for your help
Other issue,
My experience is that the dreambox (clone) rs232 chip is very fragile.
There nearly no rx/tx security's to the smd chip Sipex SP3243E (R1-in pin 4 and T1-out pin 9), only two smd capacitors, the line of the DB9 rx/tx pins going striate to the chip.
Also the print lines to the chip are very thin.
So, my advice is, be sure to use an rs232 cable with the right connections and never pull it out/in when the box is in on state. .
I would like to thank you all. After manufacturing a null modem cable i got my serial connexion working.
I used the enforcer tools and now my DM800 is up again.
Sorry for my english.
Best regards
Dear team
after I tried to install new image I get also Error: "no ca found".
Then with null modem cable I can't update because: file to big.
Pls help.
Thanks for all advices.
It works now again.
What I did:
1) made new null modem cabel: only pins 2-3,3-2,5-5,chasis
2) set serial interface on PC:57600,8,no,1,no
3) laptop and db800 with patch cabel to router
4) dreamUP start - mark network and start connect
5) hold power button on db800, then power on (220V)
6) start flash
7) after flashing ready , switch of/on
later I was also able to change image over dcc software (network)
unfortunately my SATA HDD WD3200BEVT will not be recognized
(checked with linux pc - is 100% ok)
but dm800 says : no hd connected
I have tried all the solutions even boght a second DM 800 to try combined solutins but with no luck been tring to see the images to fix "file to big" but got nothing but the restrection of this site coulde any body help please ?
can you send me the IMAGES ?
OPEN DreamUP
CHECK USE NETWORK
PRESS CONNECT
CONNECT ur dreamBox NUll Modem and LAN Cable must be mounted, u will get an IP Adress, after CA 2nd stage not found and nothing happen
Open Browser, be patient it will get a moment to OPEN and then u will have the Upgrade Firmware option available, then flash like before ur DM 800
I have flashed with serial Cable using the Tool Universal DreamUp 1.3.3.4 (only this version is working on my Dreambox!)
After you can flash a Dreambox Image but only one with the right Drivers for the Fake DM800!
