### Digital Kaos v1.1 - Updated Fast Scanning ###
  • phimay
    • 11
    #106
    DM500C setup pwds loss
    Hi Devilfish thank you very much, it me Phimay and I still having lots of problem trying to get the correct password to access the setup and access from my PC to the dreambox.
    Is there anyway I can get through the device without losing the data inside.
    Once again I like to thank you for your kind assistance here.
    Rdgs,
    Phimay
    Originally posted by Devilfish
    Hi folks,
    I gives me great pleasure to announce an update to the excellent Digital Kaos v1 image, funnily enough named v1.1.
    The only update is the inclusion of FAST SCANNING. Just like you have with the dbox2 you can now scan all channels in under 2 minutes with your dreambox. I know this is possible with a manual scan but I don't think it's been done with an automatic scan or included in an image yet. So you'll get it here first with the Digital Kaos v1.1 image. I did plan to do a v2 image but I simply don't have the time at the moment.
    Scan the channels in like you usually do...
    Menu > Setup > Service Searching > Automatic Transponder Scan
    Only this time you have options like the Set My Location plugin on the dbox2. Choose the option that is closest to your town/city and start scan. If none of the options suit you, the original settings (6887, 6952, Bruteforce & Irish) have been included. The options are listed alphabetically so it's easy to find your area.
    For those already using the DK v1 image AND if you have your dreambox connected to the internet (via router or modem), you can update to the latest v1.1 image using your remote and you don't even need to turn on your PC.
    Menu > Setup > Expert Setup > Software Update > Internet Update
    Select 'Digital Kaos v1.1' from the list and follow the prompts.
    Note: Your services and bouquets will NOT be affected, they will still be there after upgrading.
    Please refer to the original writeup for all features within this image.
    ### Digital Kaos v1 Dreambox Image for DM500 C/S/T ###
    Digital Kaos - Downloads - Digital Kaos v1.1 Image for Dm500 C/S/T
    Njoy!
    Devilfish
    • Methanoid
      • Oct 2008
      • 11
      #107
      What would be a good feature to have would be to be able to do incremental scans.
      I often find an odd channel is missing. I rescan and it appears but something else drops out. An incremental scan would only ADD new channels but not remove channels. You'd remove channels manually.
      Could that be in v1.2 ???
      • dedge_10
        • 46
        #108
        hey thats sound like a good idea
        • saj1985
          • 785
          #109
          gotta admit im lovin this image!
          just thought i'd say thanks to everyone whos put effort into it,
          and just wanted know if in the future your going to,
          add a reminder option in it, like for example on s*y digital,
          so you can put a reminder on tv guide so when the program comes on it flashes up with the reminder!
          that would be wicked,
          anyways just a thought!
          thanks again peeps!
          Dreambox 800hd se/Dreambox 500s, 90cm Solid Dish, Tm2600 Motor, TM-1 Gold LNB!
          • Digger
            • 154
            #110
            you can do that on the image,but only set one reminder...
            • saj1985
              • 785
              #111
              didn't know that mate,
              how do you do it mate?
              • Digger
                • 154
                #112
                i cant remember off the top of my head but will check later and let you know.....
                • Digger
                  • 154
                  #113
                  go intothe epg and highlight whatever programme you want. then press the yellow button and u get time edit menu. wherer it says record dvr change that to switch and save it and then when that programme is on it will switch to that programme. only problem is that u can only have one programme selected at anyone time i think, hope this helps...
                  • saj1985
                    • 785
                    #114
                    thanks a lot mate
                    • kingdom
                      • Mar 2009
                      • 10
                      #115
                      newbie
                      hi all
                      just bought a dreambox 500T adn finding this site full of great info, keep up the gr8 work
                      • ppking
                        • Mar 2009
                        Hello - I am quite new to the forum - Can you let me know please if the enigma image works ok on the DM500-c
                        • macros121
                          • Mar 2009
                          Does this image work on openmedia 500cs in both sat and cable mode? I think there is the older version of this on the box at the moment but just want to check how you flash this for both the cable and sat sides of the box. Does the same image work for both or do you have to flash twice? Sorry if this is a stupid question but new to this.
                          • MetalKettle
                            V.I.P.P.T. Member
                            • 797
                            #118
                            Yes this image will work on the Open Media box for both cable and sat. You will have to flash the image twice. Once when switched to cable and again when switched to sat if you want to use it for both.
                            Have Fun !!
                            XBMC/KODI Developer
                            • MetalKettle
                              V.I.P.P.T. Member
                              • 797
                              #119
                              Yes. See first post.
                              XBMC/KODI Developer
                              • ofokke
                                • Mar 2009
                                Is udp multicast possible?
