### Digital Kaos v1.1 - Updated Fast Scanning ###
Flash an image to 500s using Dream-Up loader & null-modem
cable. DK1.1, Pli-Jade, Darkstar 11 are good images.
Install Cccam 2.13 or 2.14 on your image. You will need to do
a bit of reading up on dreambox. Look at top of Dreambox page
at posts in RED. Also look in SAT forum in Sat Dreambox.
In DOWNLOADS--DREAMBOX--GUIDES; all the info you need is
there. Also in DOWNLOADS look at IMAGES & OTHERComment
thanks veryHi folks,
I gives me great pleasure to announce an update to the excellent Digital Kaos v1 image, funnily enough named v1.1.
The only update is the inclusion of FAST SCANNING. Just like you have with the dbox2 you can now scan all channels in under 2 minutes with your dreambox. I know this is possible with a manual scan but I don't think it's been done with an automatic scan or included in an image yet. So you'll get it here first with the Digital Kaos v1.1 image. I did plan to do a v2 image but I simply don't have the time at the moment.
Scan the channels in like you usually do...
Menu > Setup > Service Searching > Automatic Transponder Scan
Only this time you have options like the Set My Location plugin on the dbox2. Choose the option that is closest to your town/city and start scan. If none of the options suit you, the original settings (6887, 6952, Bruteforce & Irish) have been included. The options are listed alphabetically so it's easy to find your area.
For those already using the DK v1 image AND if you have your dreambox connected to the internet (via router or modem), you can update to the latest v1.1 image using your remote and you don't even need to turn on your PC.
Menu > Setup > Expert Setup > Software Update > Internet Update
Select 'Digital Kaos v1.1' from the list and follow the prompts.
Note: Your services and bouquets will NOT be affected, they will still be there after upgrading.
Please refer to the original writeup for all features within this image.
### Digital Kaos v1 Dreambox Image for DM500 C/S/T ###
Digital Kaos - Downloads - Digital Kaos v1.1 Image for Dm500 C/S/T
Njoy!
DevilfishComment
