### How to flash a dm800 via web browser ###
  • westkill
    • 2378
    DM800 Flashing firmware by Browser
    Flashing a new firmware by Browser
    What you need to flash
    You need the image file you want to flash. Image files have the extension *.nfi. You can't flash other
    images like *.img files. Don't try it - it won't work.
    You need either a DHCP server, a configured bootloader or a serial cable and a terminal program
    like HyperTerm.
    You need a browser, and a network cable. If you connect the Dreambox directly to the PC,
    you need a cross cable, if you connect trough a switch/hub/router you need a normal
    (non-cross) cable.
    To flash a new image, you can use the second stage loader. It must be present and not broken.
    The following steps assume you have a DHCP server.
    If you don't have one, you have to setup an IP address in the bootloader's serial setup.
    - Power down the Dreambox, either using "shutdown" and by removing the power connector.
    Standby is not enough!
    [IMG][/IMG]
    - (1.) Press and hold the power button. Replug the power connector into the Dreambox.
    - (3.) A text "*** STOP ***" should appear. Now you can release the button.
    The bootloader entered the "waiting" mode.
    - (4.) Above the "*** STOP ***" text, there should appear an IP-address
    (four decimal values with a dot in between). If there appears the string "dhcp" instead,
    the box still searches for a DHCP server. Wait a bit. If it doesn't change, something doesn't
    work with the DHCP server. Check wether network cable is plugged in etc. If it just doesn't
    work, set an IP using the serial terminal
    [IMG][/IMG]
    Now, open a browser on your PC.
    (1.) enter in the address line "http://ip/" (where ip must be replaced with the value in the LCD).
    - (2.) on the bottom of the page, there's a link called "firmware upgrade". Click it.
    On the next page, you can select the flash image you want to flash. be sure that it has the ".nfi" extension.
    You can't flash other images (like .img)!
    - Click on "FLASH!" and wait. It might take some time to upload and flash the image.
    - Switch the box off again, and on again. The new image should be flashed and working.
  • petermiller
    • 10
    dm800c
    i am not sure if i mentioned that i was looking for the flash for the dm800c hd to get it working once again thanks
    • jammer1
      DM 600
      can i do the some on a DM600?
      • abeltcb
        • Aug 2009
        • 40
        backup
        how to do a backup of image from the box?
        thks
        Please do not PM me for support. Ask any questions you have in the proper support forums.
        Note: Viewing Pay TV without a valid subscription is illegal
        All the files available here are kept for experimental and educational purpose only.
        • gps777
          Thanks for the instructions, flashed my dm800c successfully.
          • Louiz
            • 35
            Hi, I have just flash my HD800 with PLI image but got this message>Error: No CA Found
            Anyone can help? How do I flash a new image? Can I use Dreamup?
            • jumpinjo
              • 869
                You have flashed the wrong bootloader to your box. If your box is for eg BL72 you cannot flash with a higher BL. Yiou need to reflash the right image with Dreamup using a null modem
                • Louiz
                  • 35
                  But my dreamup cant connect to my HD800. No respone from my box when using dreamup
                  • jumpinjo
                    • 869
                    bud have you tried the patched dreamup in tut
                    • dreamlife007
                      It works on my dm800
                      • Kango
                        How to do backup for dm800hd-c
                        How do i do backup for dm800hd?
                        I
                        • Decoder
                          • 46
                          Hi Bulldog But where/how do I find my BL version - got 800HD with Sim 2.01 but don't know where to find this BL number that everyone keeps on about!!!
                          Many thanks for all help/replies
                          • jamaljantan
                            Hi Bro, I try to Flashing firmware by Browser on my DM800-Cable tuner
                            On my Dreambox WebControl there is no link called "firmware upgrade" link at the bottom corner .
                            Currently my dreambox using original image GP2 from the clone box that i bought from China.
                            Please help & advice,
                            • duriantreetop
                              • 36
                              try 192.168.1.xxx/dhtml/>enter. (xxx your box ip)
