anyone can guide me on 800HD SE flashing using network. I tried to go into the web interface. I suppose to see firmware upgrade or something like that, so that i can choose my own image and flash. But I dont see any
### How to flash a dm800 via web browser ###
I think some of the newbies faces problem on flashing images to the box using web browser method. The key steps you must do is to put the box in a flash mode. To do that you need to connect your ethernet cable to your router and then press the standby button in front. Now turn on the power and keep holding the standby button until you see the word' STOP''.
You should see a IP address appear shortly. Now enter IP address at the web browser and the flash page will appear.A wise man learn more from a foolish question than a fool can learn more from a wise answer.Comment
yes u can .. turn the box off at the back .. then by the off button at the back there a little button . press then in ( keep pressed ) and turn the power back on and watch the front screen after a few seconds release the little button and u will that the ip of the box on the front .. then type that into your web browser and click update f/w and add the file u cant to flashany information provided is for educational/experimental purposes only.Comment
No ca found
Sorry if i am wrong post but i have no ca found on my dreambox 800hd with 3 dats tryed everything it says on the web but no luck. It driving me crazyComment
Do We Need Keys and SCCE?
Boss, my bos is DM800 HD PVR. Do I need Keys and SCCE after flashed? I forgot to backup siah. If yes, anyone can PM me please?Comment
Hi Guys.
I got my new DM800 HD PVR about 2 weeks ago unfortunately stuck at the boot loader (red led flashing and TV screen blank).
I believe I could get it back working by flashing a image on it but what I worry is the keys and scce file.
As I have not been able to get my box working since day 1, I am not sure whether the box have the key and scce files or not.
Also, base on my situation, can anyone advise will the keys and scce file be intact after flashing?
Many thanks in advance.Comment
