How do i Play Files From Pc on MY DM800
  • jbennett1974
    • 17
    Hi guys im a little stuck and am wondering how i can play Movie files that i have on my PC through my DM800 im sure its possible but just dont know where to start
    DM800 (wow what a box)TM9100 Super 88CM Triax Dish Titanium 02 LNB Darkman Motor Cable Tuner
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    You need to set up a mount on the dreambox which points to a shared folder on your PC.
    First of all, ftp to the box, go to /var/mnt and create a folder called 'movies'.
    Use the web interface to set up the mount instead of the remote and menus.
    Enter the ip address of your dreambox into your browser.
    Username: root
    Password: dreambox
    Go to CONFIG > MOUNT MANAGER
    Enter in the details. (see pic)
    Make sure the folder on your pc is shared.
    Click mount and after about 10 secs you should see a green tick, that's the mount successful.
    On the dreambox, press MENU > File Mode > root > var > mnt > movies
    You should see the contents of the shared folder on your PC.
    Oh...and the dreambox will only play MPEG movies or variations of MPEG. It won't play avi, divx, xvid, etc.
    Hope this helps.
    • thered
      • Aug 2008
      • 4915
      will that work for the 7025 as well
      • Devilfish
        Administrator
        • Feb 2008
        • 7872
        Should work for any dreambox.
        If you want to stream avi files, etc. you will need to use VLC to transcode the files to mpeg then steam to your dreambox. I'll leave yous to search for that bit as I don't know off the top of my head.
        Instead of /var it might be /usr, depending on the file structure.
        • thered
          • Aug 2008
          • 4915
          thats all for another day im still not networked up yet ive been off sick for last 6 weeks so moneys a bit tight at the minute to get the gear needed
          but il keep reading and learning for when it comes round which is what its all about
          • westkill
            • 2378
            on the dm800 and dm7025 which are enigma2 the web interface is different
            im sure the mount manager is in the image via the remote on the tv
            image dependant
            i have not got a dm800 but on my dm7025 it should be done that way
            as the images on these two boxes i think are very similar
            some one correct me if im wrong
            • Devilfish
              Administrator
              • Feb 2008
              • 7872
              Thanks westkill, only ever used a dm500, hopefully get a dm800 soon hehehe.
              • nut
                • 14
                im having this problem? how do you mount a p.c drive to the 7025 so i can watch movies from the p.c on my t.v through the dreambox anyone can help me set this up please?
                • tul
                  thnx it really helped me out
                  • imthedaddy
                    • 4
                    I'm useing nabilosat blackhole image, when I type my dm800 address in browser I get the blackhole image and that does not give me a mount option is there something that I am doing wrong ?
                    • cronicus
                      can i record like that on mounted hdd from my PC...thnx
                      • nagraview
                        Username: root
                        Password: dreambox
                        Hope this helps.
                        Many thanks.....
                        • wagner506
                          • Mar 2009
                          dreambox7000?
                          is this working on dm7000s ?
                          • conair
                            Hallo there
                            I know this is an old thread but i'm new to that.
                            Is there a quide on how to mount on DM800 (like view movies from a PC or an extenal USB drive)???
                            regards
                            • zaradoct
                              hi all,
                              I can record what is displayed on my DM500 on my PC using mFaraj Dreambox Viewer and everything is ok. But I tried several times to see what was recorded on my PC back to my DB but never worked.
                              Please can anyone explain this step by step for a newbie like me
                              Thanks all.
