Belfast, all channels went off
  • Bonesy
    • 655
    #46
    Originally posted by breger
    Did u get all the atatiopns back with the rescan. Premier and sky 1 dont seem to be working for me.
    yes, all there as far as I can see.
    Setup: 2x Dreambox 800HD | 3x Dm500S on Motorised dish Setup
    • Bonesy
      • 655
      #47
      Originally posted by cloudnineuk54
      good luck mate let us know how it goes,best to read everything before attempting,if using dream up most peeps get stuck on not setting com port up properly
      All he needs is dreamboxedit. It will load the files in belfast folder and ftp them to the dreambox for him.
      • MIA500
        • May 2010
        • 11
        #48
        X + 1?
        Originally posted by GoodPrognosis
        Go to a command prompt on your PC.
        Type ipconfig and look for the ip address of your PC.
        It will almost certainly be something like this:
        192.168.1.x
        Your dreambox will be x+1 or possibly x+2 or 3 depending on how many other bits of kit you have.
        Just trial and error it until you get the right one.
        GP
        Thanks GP,
        Could anyone provide info on X+1 etc
        For example if my CPU IP address is 192.168.1.54
        Would the IP of the dreambox be 192.168.1.55 or would it be 192.168.1.54.1
        Hope you can understand the above.
        • wazza233
          • May 2010
          • 13
          #49
          Originally posted by Bonesy
          That will not work, factory reset will erase your cam files also.
          just grab the new file I uploaded a few posts up and use dreamboxedit to ftp them to the box...job done.
          Hmmm this isn't as straightforward as I thought it would be haha, can you recommend any step by step guides on how to do this? Also, I assume I need to be using a crossover cable?
          • wazza233
            • May 2010
            • 13
            #50
            Hey, after a bit of messing about (Was for giving up haha) I finally got it sorted.
            Dreambox IP set to 192.168.1.1
            Network adaptor set to 192.168.1.2
            All the rest default settings, didn't bother to back up old files as they are now out of date and useless, selected files I had to load in and then clicked send files to DB. Also, one thing I have noticed since putting on the new files is that I now have more of a transponder choice (Used to have only 5 or so, now there's a long list and was able to select one specifically for my area)
            So thank you guys for the info and Bonesy for the files, keeps my DB going a bit longer until they all go for good.
            • 2tone
              • 483
              #51
              Originally posted by Sirus
              Has anyone else seen that when you go to "information" and look at an encrypted channels "stream info" its says coding systems used
              1800h Kudelski (which is N1)
              1841h Kudelski <<<<<< N3 test phase running parallel with N1
              That's definitely only showed up recently, as I check this every now and then.... so I guess the more obvious question here is - how longs these test phases last until cleared to switch over?...as thats when we're screwed for good
              and from that you could bet new cards wont be long talk digi boxs are working in derry and this is thought what would happen get derry digi and roll out new cards this will be fun
              • tennents
                • Oct 2008
                • 29
                #52
                can some one point me in the right direction a mate done a factory reset on his box ive never done a dreambox before no other boxes but not these ones when i scan its showing me all the channels when i go to skysports 1 hold info for three seconds and evocamd 2.12 stops and runs again its showing me channels but when i go into them there blank ive went in and had a look in banquet but nothing there ive i need to redo the box any1 no were i can get a workin image for dream box 500c thanks in advance
                • chers
                  • May 2010
                  #53
                  Ok, just finished and have uploaded new chanels & bouquests are now updated and sorted and more importantly working
                  Digital Kaos - Downloads - Northern Ireland Cable
                  So, enjoy and dont forget the thanks guys.
                  nice one , going to check this out. Im trying to sort one of these boxes for a friend,they are a little confusing,. Anyway Ill try what you suggested & get back. Thanks for your time & effort.
                  • chers
                    • May 2010
                    #54
                    lots of files in that folder, do i just send the folder to the box or each file individually? Just to confirm , these files are for dream-multimedia-500?
                    cheers again mate
                    • wazza233
                      • May 2010
                      • 13
                      #55
                      cheers again mate
                      Hi mate, the way I did it was just browse and point the program (Dreambox edit I used) to the Belfast folder and then connect DB up and hit "Send files to Dreambox" then "Reload settings on Dreambox" worked for me.
                      I have a DB500C and they worked perfectly.
                      • Bonesy
                        • 655
                        #56
                        do as he says, use dreamboxedit program, makes it easier for you and does all the business automatically....dreamboxedit is available in downloads section.
                        • tennents
                          • Oct 2008
                          • 29
                          #57
                          can i use this bonesy even no the mate done a factory reset thanks mate
                          • Bonesy
                            • 655
                            #58
                            factory reset will erase roms etc.. also so no it will not work with you putting all the roms and keys back on the box.
                            • danny123456789
                              • May 2010
                              #59
                              hey gys thanks sososososos much i thought i lost my chanels 4ever
                              • ricoman72
                                • 13
                                #60
                                Guys, Ive loaded the contents of the belfast folder via dreamedit & uploaded to the db but the bouquets havent changed. The original ones are still there with service removed in every folder. All channels are listed under the red button. Any help with how I can get the bouquets to update? I'm using the DK image v1.1 on a 500c. Thanks.
