HQK 3388
  • jimmysim76
    • 5
    HQK 3388
    Got a HQK3388 digital box, any brothers know how to get the world cup channel and upgraded channel like 102 cos the box is still using the whole channel listing.
    Thank
    Cheers
  • ultrakiasu
    • 128
    Menu, Channel Edit, Enter Password, Manual Scan,
    Select QAM-256, and individually scan the common frequency bands.
    Remember to save setting after exiting the setup menu.
    • racingmaro
      Select QAM-256, and individually scan the following frequency:
      378kHz or 378000 Hz
      474khz or 474000 Hz
      578kHz or 578000 Hz
      594kHz or 594000 Hz
      Hi friend theres no place to key password at channel edit
      anyway ard it?
      Under my ch edit theres
      Fav Set
      Parent lock
      Add/Del
      Adjust
      Rename
      Del All
      • jimmysim76
        • 5
        378kHz or 378000 Hz
        474khz or 474000 Hz
        578kHz or 578000 Hz
        594kHz or 594000 Hz
        Bro
        Thanks for your advice.Try out your steps but cant get it rite.
        The problem now is that i can only watch local channel and all in the previous setting like 02 for channel 5.
        Those cable TV program when i switch to channel it will be blank and no sound coming out.
        I suspect that maybe my smart card is block or?
        Like what the bro mention below , no place to key in the password channel edit.
        Any other advices you can offer.
        Thank you
        • kccho
          hi,
          what is the frequency of vv drama ch 855?
          thanks.
          • ultrakiasu
            • 128
            Sorry!!! I am recalling the HQK3388 menu based on my memory, its a long time since I meddle with such unit.
            Its not under Channel Edit, It should be under Channel Scan, or something to do with Channel Scanning.
            Select the Manual scan!!
            DO_NOT_AUTOSCAN!!!
            • jimmysim76
              • 5
              DO_NOT_AUTOSCAN!!!
              Ya brother, i use manual scan but still not valid, need i need to get a new smart card anyway thanks for your help.
              • ultrakiasu
                • 128
                If the older channel is still viewable, u don't need a new AUCard to view World Cup channels.
                I can help you with AUCARD for HQK3388 / HQK6633 / FY901C / 2010 / AA898.
                Sorry, I don't have DM900C-II AUCARD.
                • ultrakiasu
                  • 128
                  Originally posted by kccho
                  hi,
                  thanks.
                  QAM-256: 5*0 MHz or 5*0000 kHz
                  • jimmysim76
                    • 5
                    Bro:
                    Like i mention, i cannot watch any cable channel on this box with existing card. All the screen is blank when i switch to the cable channel.
                    Can only watch the local TV channel.
                    So to say maybe my card is faulty or being block.
                    Thank you for your help.
                    • nerfnerf
                      • Mar 2010
                      • 4
                      my card same jimmysim 76.
                      cannot view other than 5 and 8 channel
                      • sbu7360
                        • May 2010
                        • 15
                        need to get a new card already.. *hub did a big mess to all of our sets...
                        sad...
                        • jimmysim76
                          • 5
                          Originally posted by sbu7360
                          need to get a new card already.. starhub did a big mess to all of our sets...
                          sad...
                          Ya , then f###ing sian. Now dun know where to get the C##d also...
                          • matteosg
                            • 5
                            I did a rescan on my HQK3388 & now all the channels are gone. Can you help?
                            matt
                            • mangkuk
                              Guys I had the same model ,the channels are all mess up,can i used dreamup to fix this.
                              experts any ideas?
