HQK 3388
Did you manage to flash the firmware? How you did the backup of the software? Can pm me to share your solutions? Thank you.Comment
Hi tspt88,Thank you mate, your softwares are working fine.
Infact my box dead more than 6 times by trying all the files, as i felt that since it's got, i tried on another computer with repeated of flashing different files, n it worked on SG100223_SprBx.ar.
Mate, duriantreetop's attachments are ok, may your procedure is not correct, pls follow the steps of flashing in the attachment (dl from web, it is in chinese). hope this help.
I had 2 "FY 901 C", set A and set B. I mess up set A channels sequence, and set B channels sequence is ok. If there any way to close set B channels into set A, so that both sets A and B have the same channels sequence? Thank you.Comment
1***65289; to clone is jtag flash chip, not easy and need jtag SW n specific jkeys.
2***65289; flash both box with Duriantreetop firmware n rescan same way, u get both boxes to b identical.
3***65289; clone the flash chip, this is more troublesome.
4) box is so old, not worth all the trouble (***8807;^***969;^***8806
Sent from my GT-I9100 using Tapatalk 2Comment
ks9799, i can see that u r trying very hard to get the both boxes to be identical, however, i feel that if it is still working just bear with it , cos flashing of the new firmware might brick your box into unuseable stage. unless you are like me prepare to thrown it away, that you may try.
As it was donkey years ago, I also forgotton how i manage to save the box, so just recall :
WARNING : YOU MIGHT BRICK YOUR BOX !!!!!
1. U must get a null cable (without it, no way u can flash the SW) ,try find a old computer that equiped with the serial port.
2. download the SW from post #62,67, 69.
3. instruction DL from post #73
4. follow the instrcution step by step, but do not power on the box
5. after the step 6 (the instruction step), turn on the box, the TV set should show the progress of the upgrading.
6. when complet, it will show the upgrade sucessful.
7. reboot.
I m trying my best to recall , so some steps could be missed. so u must be prepare if it brick. if so, just repeat the above steps with another image file.
Pls note the above is to upgrade the firmware not for backup of the box.
Good luck ! m8.Comment
Noted with many thanks1***65289; to clone is jtag flash chip, not easy and need jtag SW n specific jkeys.
Ok. I will take your advice and bear with it. thanks a lot.ks9799, i can see that u r trying very hard to get the both boxes to be identical, however, i feel that if it is still working just bear with it , cos flashing of the new firmware might brick your box into unuseable stage. unless you are like me prepare to thrown it away, that you may try.
7. reboot.
I do have this problem. Do you managed to resolve this problem? If yes, can share your solutions? ThanksAnyone facing this problem with HQK3388.
Pressing any channel related button will bring you to a preset channel.
Hit OK, navigate the channel to your preferred channel, press OK, but it bring u back to the default channel.
Pressing Setup, and Exit, it will bring you to this default channel instead of staying on your original viewing channel.
Anyone know how to resolve this problem?
Will flashing the *.AR files from FY resolve this problem?
Anyone tried?
PS: Anyone still looking for AUCards for DM900C-II and HQK3388/6633?Last edited by ks9799; 2 June, 2013, 09:26.Comment
