All DM900CII user that did a Master Reset and unable to view channels, Come In
This topic is closed.
  • DreamersDVB
    • 245
    #166
    KAWANG CARD
    Yes fully agree with bro SGDVB.
    Onemore thing need to highlight if you getting the card,ask your supplier what is the the card configuration code.
    The card come with 3 type of configuration.
    1. 1f-8f
    2. ffx8
    3. 8cxxx
    This is because your boxkey need to recognise the card.
    For DM900CII you can have card config 1 and 2.
    For FY901 and HQ3388 you should get card config 3.
    Hope this help.
    • zaki1462
      • 9
      #167
      Originally posted by DreamersDVB
      Check your boxkey press yellow button on your remote than punch 32768. See whats the boxkey than let me know,will guide you step by step.
      Already tried that but nothing appeared on the screen......
      Btw mine is DM 900C11, firmware 14 May 2010 and i just purchased the mentioned king card. Already master reset twice but still no channels except for fta....any help is appreciated. Thks
      • DreamersDVB
        • 245
        #168
        900
        On and connect to tv.Go to channel 1(preview ch).Press yellow button,menu screen will appear. Ignore the menu screen.Press 32768 fast one..Boxkey will appear.If didnt appear,Off and on STB again,repeat this procedure i m sure the boxkey will appear.
        • zaki1462
          • 9
          #169
          Thks alot...its working fine now
          • maxer
            • Jun 2011
            Originally posted by mableaqua
            Hi, you know the 4-digit input code ?
            hi seniors,
            can i have the 4 d code as well?tks
            • DreamersDVB
              • 245
              #171
              900
              Guessing code 3773,7337,0000.This code is preset by different2 factory. But why you need the code for?
              Originally posted by maxer
              hi seniors,
              • Badut98
                • Feb 2012
                #172
                Any way to solve 900cv sound issue
                • Badut98
                  • Feb 2012
                  #173
                  Dm900 cv any way to solve the sound issue
                  • ammadbro
                    • Mar 2012
                    • 5
                    #174
                    any pros here?
                    any pros here on dm900cv ? i need some help
                    • jatrophaseed
                      • 589
                      #175
                      Goto info if firmware is earlier then 16-8-2010, pls throw away the box. Too troublesome and costly to upgrade.
                      this goes for 500C DVB, 500CV, 500CII, 900C DVB, 900CII and 900CV.
                      If 16-8-2010 and later, just put in a WangKa.
                      All this box are from the same manufacturer FY.
                      These boxes are NOT DREAMBOX discussed here.
                      • ammadbro
                        • Mar 2012
                        • 5
                        #176
                        What is wangka?
                        Yes I know they are clones. I will check the firmware and get back to you bro. Meanwhile. Can u link me to any upgrade tutorial? And will I be able to get euro fifa? The box comes with auto roll btw so I will be able to use the box even after frequency changed mah.
                        • jatrophaseed
                          • 589
                          #177
                          What is wangka?
                          No way the box is Auto-roll without card. No tutorial. Can manually scan 346 to 690 at 8 interval to get Uefa. At the price of S$40 each in China, u mite s well buy a new 1. WangKa, pls read earlier post around last 2 years. That means yr box is too old liao.
                          • ammadbro
                            • Mar 2012
                            • 5
                            #178
                            huh ? that means my dm900cv box is not auto rolled? the add clearly said its auto rolled. can pm me which web to get it at s$40. and so to get uefa i just do a manual scan from 346 to 690 transponder frequency?
                            • jatrophaseed
                              • 589
                              #179
                              You can google for the supplier in China. No use scan 346 to 690 if yr box is not working. In China, a Proverb quote: all thing is fake, only cheats are real. Only firmware after 16-8-2010 can auto-roll. Any b4 dat NO!!!!
                              • ammadbro
                                • Mar 2012
                                • 5
                                #180
                                Pheww thankgod my firmware is 2011 i already have the channels so i guess even if they change the freq i will still get the channel
