All DM900CII user that did a Master Reset and unable to view channels, Come In
This topic is closed.
  • CableGuy888
    • Jul 2010
    #16
    After Trying Your Reset
    Hi nipulu77,
    Tried your method that you describe, was able to reset the system and enter the "F8 key" but channels with "dollar Sign" not able to view only free channels can view,
    Please Help...
    Desperate CableGuy888
    Originally posted by nipulu77
    Recently on 18 Jul, Key changed, resulting in many DM900CII user unable to view.
    I know nothing abt setting/flashing, not to even mention recover, in the end did a master reset on my 900CII, till now I admit this is a stupid thing to do.
    thru many email advice and MSN message and lots of help from many brother. Please refer to below for those people, who master Reset their DM900CII, and don't know how to recover.
    The guide is only for those who did a Master Reset
    1. By all mean, i assume you master reset your device, now
    do another round of Master Reset
    2. Once reset, on 900CII, will prompt you for auto tuning,
    skip this, by pressing YELLOW to go into MENU, select TP
    range tuning.
    Range: 304 to 698, proceed to search
    3. When done, i have around 120++ channel detected.
    Press YELLOW to go to MENU again
    Press BLUE repeatly till COMMAND Box comes out
    Command: f8 ....................
    "..............." meaning after f8, the rest all ff
    i know key is not allow, therefore i try to "shorten the key posted here".
    4. It should work and all the channel are back and "viewable"
    or "watchable"
    yes I know all channel inside, but how come all channel s position is all mess up.
    Well, I can help till this stage, i am still figuring how to put those channel postion back to default position.
    BUT at least your box is usable, need not to spend money on new cards or new dreambox.
    • nipulu77
      • Jul 2010
      • 12
      #17
      1st, are you using DM900CII?
      I only know this model, the rest I don know.
      Do a master reset again, then TP scan.
      then
      Command: f8 ffffffffffffffffffffff all the way.
      this should work already
      • CableGuy888
        • Jul 2010
        #18
        Model is Correct
        Did exactly what you mentioned, still it did not work...my demand channels are gone after master reset, would greatly appreciate if you can suggest other alternative.
        Thanks!!
        CableGuy888
        • nipulu77
          • Jul 2010
          • 12
          #19
          get someone who has DM900C-V(having the latest firmware/image, to perform upgrade, will be fine.
          I did this, only to re-arrange back my channel.
          • mogcool
            • Jul 2010
            DM900CII
            I seem to lost the keys.
            I cannot view any channels.
            Can any of my brothers help me get back the channels?
            Thank you.
            • Hwee Siang
              #21
              How do you do a master reset???
              • cloverxuan
                #22
                DM900CII
                I did not do any reset can i cant view any of the digital tv channels at all. shud i reset? anyone can help?
                • Hwee Siang
                  #23
                  I followed your instructions from the system master reset and all I got was only channel one (a European channel) the rest did not work. Do you think I can still do an update like one of the members' recommended?
                  box not working for the past few days. We managed to program the world cup recently but system suddenly stopped working some 3 days ago.
                  • stuckSH
                    mine too as well.. anyone knows what had happened? some says card expired.. true??
                    • nipulu77
                      • Jul 2010
                      • 12
                      #25
                      I upgrade my 900CII with 5th Gen Card inserted <--> DM900C-V, rubbish box turn into usable box.
                      I'm not sure if upgrade with 2nd Gen Card or old card, will solve problem or not
                      Reply from China side:
                      those DM900CII user this few days, unable to view channel, due to unknown reason, even if we have key in the correct code, but unable to watch, means that need to change to new card --> 5th Gen Aucard.
                      I perform system udate my 900CII - DM900C-V via serial cable, with 5th Gen aucard plugged in, problem solved.
                      Therefore, to solve the problem, new card is needed.
                      • angsana
                        • 30
                        #26
                        hi care to share how much u paid for this card and from where?
                        • Bai
                          • Jul 2010
                          • 4
                          #27
                          hi nipulu77,
                          do you have the picture of
                          the 5th gen card cause some of those using dm 900 c not affected
                          • Arraysys
                            • 173
                            #28
                            Take Note !!!
                            The 5th generation card does not support auto key roll in DM900Cxx. If provider change the key, you need to manually input the correct key again in order to watch. But the card work petty well on auto key roll in others box like 801/5288/5688/2011, mk3388, fy901c, ...
                            To test on your dm900c, try changing the key 00/01 to any any incorrect key. You will face cannot watch paid channel. Even for a couple of minutes still cannot autoroll. This prove that it doesn't support auto roll key.
                            • mpsm
                              • Jul 2010
                              thanks it worked for me
                              • Arraysys
                                • 173
                                #30
                                The new 5th generation card can allow you the watch all channel on dm900. But the card will not get new key transmitted from the provider (SH). It does support the automatic key roll feature only.
