SKY BOX OFFICE CONFIRMATION
  • vishal88
    • 20
    Hi just to let you know if you are using the live events channel that shows hatton on the left and cena on the right, this will not be showing the live event. you must follow devilfish's guide here:
    I live in croydon and followed this guide. instead of using 555 for frequency i used 507, to check which one works for you enter one of them and if lock and sync and unticked then this will not work. try the other one and when the lock and sync is ticked you can proceed with the guide in the like above. when i did the scan it came back with 9 new channels. you will need to restart your box and then go to sbo. there should be some background music with a picture of only ricky hatton in the center and not with cena.
    so to ensure your on the right channel plz note the advice given above
  • bigman2
    • Oct 2008
    • 52
    I tried that and input everything and it found nothing after the scan. Does that mean non one in my area has bothered to buy the fight ?
    I guess I will have to watch it on polsat.
    • toto67
      • Feb 2008
      • 178
      Can someone from TW Lanarkshire area cofirm the info needed to manually enter this please..I think the settings from Glens above thread might be different now guys..Anyone confirm as I aint able to access me DB as at work...
      • caveman_nige
        • Feb 2008
        • 4920
        Originally posted by toto67
        Can someone from TW Lanarkshire area cofirm the info neede to manually enter this please..I think the settings from Glens above thread might be different now guys..Anyone confirm as I aint able to access me DB as at work...
        These did nothing for me either
        • toto67
          • Feb 2008
          • 178
          What did you get when you scanned it using Glens
          settings m8?
          • Scarface
            • 92
            I have tried all the options and nothing also, I'm in South Yorks.
            • Donnie Darko
              • 442
              I've got boxing on at the mo,sbo2 with a box office events icon top right,assuming this is the channel.
              Also got a load of other channels either jumbled or missing,which i'm more pissed about,ex-cw also.
              Checkout the RED stickies massive amount of info and effort been put into them.
              • toto67
                • Feb 2008
                • 178
                Anyone thats got it working,can you tell me what its displaying at the mo?
                Is it just pictures etc or is there like a preview of the fights etc etc..Thanks
                • Donnie Darko
                  • 442
                  SBO PPV2 showing fighting at the mo,not rolling ads or still pics.Live events showing still pic advertising fight.
                  • toto67
                    • Feb 2008
                    • 178
                    Ok,it sounds as though the one showing some type of boxing,will be the one that airs it m8...Could you double check the settings on that are similar to Glens above post m8 on manually editing them? Could you do that m8?
                    • MrJayT
                      • 20
                      so the lock and sync have to be ticked? cos they arent when i use 555 or 507
                      • MrJayT
                        • 20
                        lock and sync are ticked when i use 627 but when i put in the pids it says " a transponder with the same tsid / onid but other frequency/pol/...already exists...create a new transponder with the same data is no possible... please do change tsid and/or onid"
                        • toto67
                          • Feb 2008
                          • 178
                          Yeh m8,wont let you have 2 of them with the same settings.Just go back and delete it from the services......
                          • Donnie Darko
                            • 442
                            <TS id="0065" on="f020" frq="627000" inv="2" sr="6952000" fec="3" mod="3">
                            <S i="007a" n="God Channel" t="1" />
                            <S i="007c" n="SBO PPV2" t="1" />
                            <S i="007e" n="Sci-Fi Channel" t="1" />
                            <S i="007f" n="British Eurosport" t="1" />
                            <S i="02e9" n="Five US" t="1" />
                            <S i="02ea" n="Teachers' TV" t="1" />
                            These are neutrino,excw services.Checkout freq 627000,TS id etc.
                            They look different to other services but you just need to edit required figures into say enigma services in correct location.
                            • Scarface
                              • 92
                              The coverage started at 9pm so at the moment the undercard fights will be showing, if anyone is actually getting that maybe they can post settings.
