Think hes given up m8.......
SKY BOX OFFICE CONFIRMATION
Right,is there ANYONE else up at this god forsaken time trying to get this to work? Try these settings instead of the ones already posted to see if this helps guys
VPID : 0515
APID : 0663
To note: These are for Glagow TW are folks.....
Ok,so as NO confusion and edited post..
Go into scanning menu...
Menu > Setup > Service Searching > Manual Search
Frequency - 555MHz
INV - ON (ticked)
Now select Yellow button (PID)
Name - Sky Box Office Sports
Provider - 555 or 507 or 627
Video PID - 0515(instead of 0203)
Audio PID - 0663(Instead of 0297)
PCR PID - 007b
Teletext PID - 0243
TSID - 0007 (for ex-tw)
TSID - 007a (for ex-ntl)
TSID - 0064 (for ex-c&w live events channel)
TSID - 0065 (for ex-c&w SBO PPV2)
ONID - 1020
Service ID - 06a4 (for ex-tw)
Service ID - 0275 (for ex-ntl)
Service ID - 0067 (for ex-c&w live events channel)
Service ID - 007c (for ex-c&w SBO PPV2)
No DVB - Untick
Use SDT - Tick
Save settings (BLUE)
Start scan
Should only take a few seconds and should return 2 new services.
Exit out of the menus.
Press OK then RED (All Services) and scroll down to Sky Sports Box Office. Should work ok.
If provider 555 doesn't work, try 507.Last edited by toto67; 23 November, 2008, 03:16.Comment
If Devilfish`s tut is a generic one, what settings change from region to region, the frequency stays the same, but three options for Provider, which none work for me. toto67 posted setting's with diff VPID and APID, and states you have to reboot, do you reboot only if it finds any new services?? No matter which provider I enter it only ever finds 1 transponder but never any new services. Is there anyway to find out the settings for a particular region from somewhere?Last edited by Scarface; 23 November, 2008, 10:51.Comment
Well how did this all turn out, did any of you guys manage to pick up the channel last night/this morning. Personally, after finding out in the early evening that i was looking at the wrong channel i tried the guide from DF for a while and found ~~~~ all. Lets just say that after that I could not be arsed and went onto other things...
Those that have it, stream info would be good so that we can all set it up for future use etc...Comment
also no luckRight,is there ANYONE else up at this god forsaken time trying to get this to work? Try these settings instead of the ones already posted to see if this helps guys
VPID : 0515
APID : 0663
Frequency - 555MHz
INV - ON (ticked)
PCR PID - 007b
Teletext PID - 0243
ONID - 1020
No DVB - Untick
Use SDT - Tick
Start scan
If provider 555 doesn't work, try 507.Comment
I get all the other channels you listed with the info you provided Donnie Darko but not the SBO PPV2...
But I had those anyway..Last edited by caveman_nige; 23 November, 2008, 13:23.Comment
OK, here its is from my settings.. Found it at last, to be honest it probably already there. I went into User Bouquets (pressing OK from any TV channel) and pressed the red button for all services. I scanned through there and found all the attempts i had made to manually scan for it and just flicked through them. None had the signal indicator bar beside them.. howver one of them had boxing one.. details are below..
Stream Information
Service Name: sky box office sports
Service Provider: 627
Service Reference: 1:0:1:7c:65:1020:0:0:0:0:
VPID: 0206h (518d)
APID: 02a6h (678d)
PCRPID: 0286h (646d)
TPID: 02d6h (726d)
TSID: 0065h
ONID: 1020h
SID: 007ch
PMT: 0020h
Video Format: 544x576 16:9 25 fps
Frequency: 627 MHz
Symbol Rate: 6952 KSymbols/s
Inversion: Yes
Modulation: 64-QAM
FEC: AutoLast edited by caveman_nige; 23 November, 2008, 13:43.Comment
got it on dbox no problems whatso ever, no messing it was there when i switched the channel on, couldnt get it on the dreambox, the dreambox seems a stresser trying to get it to work . a neutrino image on the dreambox would pick it up i would imagine. as thats whats on the dbox.Faster than Faster
SBO is still transmitting the boxing right now, did have a problem last night, after entering the details, was getting a reply back saying the ONID was in use when tried to press save (blue button)... or something along them lines, so delete the channel 515 which was using very simluar info.
re-entered the details then it worked fine.
hope this helps someone.Last edited by birkenhead; 23 November, 2008, 13:53.Comment
