what image are you using???
some of them don't have Tuxbox commander installed on them, so you'll have to install it manually...
if you can FTP scroll up to my last post and download the file and install it.
but if you can FTP it's allot easier to do it that way
navigate through var/keys/ and double click on KEYLIST.TXT and that should open it in notepad, edit the key, save it to desktop, then FTP it back over to the same place. it should ask you if you want to overwrite the file you say yes, and off you go...
most cams are under the blue button, but if your using the DK image press and hold the info button.
or if you cant find it pull the power and it should see the changes on start up....
Good luck...
Good luck...
