I want to put dbox 2 in d bug mode - Help
  • piptaps
    • 399
    #31
    Can i use the ppcboot read_flash file? When i downloaded bootmanager there were 2 ppcboot files inside it. 1 was write_flash and the other read_flash
    • piptaps
      • 399
      #32
      I have now managed to pass the first step. After clicking start the box try to Boots but its not going into the reset screen. I tried whats on the guides, holding the sleep and up button together, but still the box is not going into the rest mode. Its coming up with these in the comms:
      ***Adapter Desc: Intel(R) PRO/100 VE Network Connection (Microsoft's Packet Scheduler)
      ***MAC address: 00:11:11:E5:49:5E Local IP: 192.168.1.67 (via Packet-Driver #1)
      ***BootP server started... Port 67
      ***TFTP server started... Port 69
      BootP> Answer sent!
      BootP> Answer sent!
      BootP> Answer sent!
      RARP> Ignored, because requested MAC is 00:50:9C:18:7D:25, expected MAC 00:00:00:00:00:00 (DBox-IP: 192.168.1.202)
      RARP> Wenn die expected MAC mit C0:.... beginnt, ist das H?CHSTWAHRSCHEINLICH ein 10/100MBit Problem! - Lest das Readme dazu!
      • Elric
        V.I.P. soft lad
        • 853
        #33
        try a few times sometimes the boot manager dont work
        on the first boot
        • Fergal
          • Aug 2008
          • 1007
          #34
          You can only use the ppcboot file
          BootP> Answer sent!
          BootP> Answer sent!
          BootP> Answer sent!
          RARP> Ignored, because requested MAC is 00:50:9C:18:7D:25, expected RARP> Wenn die expected MAC mit C0:.... beginnt, ist das H?CHSTWAHRSCHEINLICH ein 10/100MBit Problem! - Lest das Readme dazu!
          You have set your pc nic to 10baseT_halfduplex or 10halfmode?
          when you get reset in the lcd press and hold the up button in till you get the row of numbers at the bottom of the Lcd.
          now do the flash reset short with the wire you will see the 5 blocks appear between the numbers
          as soon as you see the 5 blocks release the wire or what ever you are using to short it
          If it starts to flash “reset” again repeat the above till you get the 5 blocks.
          Then release the wire
          now you should be able to type the commands in the com window
          • piptaps
            • 399
            #35
            Yes i have set my PC to 10mbit/half duplex. Let me keep on trying the bootmanager programme
            • piptaps
              • 399
              #36
              I have made a slight progress. On powering up the dbox it flashed reset twice then revert to Lade.... Since then i have tried but its going straight to Lade...
              • piptaps
                • 399
                #37
                Guys i dont know where i am going wrong. I still cant get a reset flashing on my dbox 2. I have read the guides all over again countless times but still the box is refusing to flash reset. my settings on the bootmanager are as below
                • MetMan
                  • 1091
                  #38
                  try creating a dbox2 folder on ur root drive C:\Dbox2.....install bootmanager into this folder.....then add this folder to it
                  tftpboot.rar
                  make it look like this with the box ip and ur network card
                  • Fergal
                    • Aug 2008
                    • 1007
                    #39
                    You have it pointing to ppcboot_flash(2) which is wrong the file is called ppcboot nothing else try this one
                    • piptaps
                      • 399
                      #40
                      fergal i have used the ppcboot file you put above but still the box wont go into reset mode. Its the 1.0 version so i it has to go into reset mode first before i can SHOT it. Been seating here 2 days i a role now and feel like giving up.
                      All settings are correct. 10mbpt/half duplex, static IP address, turning off fire wall and anti virus. I can see the Box booting up in the bootmanager comms window, but still the dbox wont go into reset.
                      Help guys. What other trick could i use
                      • piptaps
                        • 399
                        #41
                        Here is the screen i am getting. At the bottom its saying the box failed to Pingg, and at the top it looks like the box is booting up. But still i cant get it flash reset on the LCD
                        • piptaps
                          • 399
                          #42
                          any more help guys!!! am really new to this and still leaning my way
                          • Fergal
                            • Aug 2008
                            • 1007
                            #43
                            Let the box boot up fully for about 5 minutes while its doing that unistall dboxmanager and reinstall it into C:/
                            put the 3 ppcboot files into C:/
                            reboot your pc and power the box off then try again
                            you can press and hold the power and up button in until the lcd goes blank then let go to do a power reset
                            instead of unplugging all the time i think.
                            • piptaps
                              • 399
                              #44
                              thanks fegal. i have managed to send the box into reset. i have done this via the image flashing assistant. once the box was in reset i SHOT it and closed the image flash assistant, and opened the bootmanager programme. i was able to write commands but it came up with this message:
                              Non-BootP TFTP-transfer requested "kernel-cdk"
                              TFTP> Couldn't initiate TFTP-transfer! (possibly file not found)
                              TFTP> Non-BootP TFTP-transfer requested "kernel-cdk"
                              • Fergal
                                • Aug 2008
                                • 1007
                                #45
                                You need to get it to reset using dboxmanager dont use the dboxmanager the comes as add on with ifa use the stand alone version and dont worry about it saying ping failed in the bottom right corner this is normal.
