mine eurobox says eurovox max....
it got red version of firmware..should it take eurovox max v 2008 firmware too
No, use the black max v firmware. Also you need to drop the signal strengh to 73% this is due to the fact that servers have been taken off line and VM are testing a new system, eurovox's are the only one sensitive to it. A variable attenuator should do it. Best time are early morning or late at night.
it says
this firmware is not fit for your reciever...
what to do nxt..i m not leavin it till you guys hav som ways out
If it took the red firmware its a 2007 Red max model. It will not take the Max V firmware.
As said in a previous reply did you check the coax was in the RF in socket when scanning and if it was and still no signal, plug the coax directly into the TV and report back what you do/do not get.
is it common that it is picking up all freq. and scanning all channels with name and taking around 20 mins for scan...when all is done ..each channel says no signal..
nd do i hav to put keys manually ..key 00>>>key 01
if so then what should i put..i m usin virgin ntl
Yep if you have the channels then its getting to your box so it may not be a cable in problem as it is picking up transponders. The no signal problem is as I said VM, the strengh is to powerful while they are messin I had the same problem last week when I rescanned.
ya its the same firmware i dwnloaded...
tell me how todecrease the strength to 73% as you said..all channels say scrambled and i put the keys according to the keymaster and the free channels are saying service unknown....
first of all lets test what signal you got, press the info button twice on your remote, it should give you the signal in strengh, what is it?
