How do I rescan on a Eurovox 1100
  • wellseytkd
    • 26
    How do I rescan with a Eurovox 1100? It doesn't seem to be working Ive set the rate to my area but it scans within seconds and doesnt put any channels in?
    cheers
    A
  • smoggy
    • Apr 2009
    • 12774
    have you put in the start and stop frequencies 100.00 start 870.00 stop
    • wellseytkd
      • 26
      do I do this in power scan?
      • smoggy
        • Apr 2009
        • 12774
        yes, put in stop and start frequencies and your symbolrate in first box put o in other symbolrate boxes and scan on step 8
        • wellseytkd
          • 26
          in start and stop frequencies i put 739 and 739 in symbol rate i put in 6887 in the frst box and the rest 0 and the step 8mhz and it found no channels
          • stiffler
            • 10
            sorry to jump in on your post, some chanels have gone on my ex1100 and im teeside based. Do I need to rescan or reflash the box?
            Tried power scanning but to no avail. Am I doing something wrong?
            • smoggy
              • Apr 2009
              • 12774
              I'm not surprised as you are scanning only one frequency that probably has no channels associated with it.
              Start = 100.00 Stop = 870.00
              • smoggy
                • Apr 2009
                • 12774
                You only need to rescan but do a factory default reset first to remove all the dead channels
                • wellseytkd
                  • 26
                  Ok Ive scanned with sybom rate 6887 and from freq 100 to 870 and still nothing :s
                  • stiffler
                    • 10
                    same, nothing
                    • smoggy
                      • Apr 2009
                      • 12774
                      is 6887 the correct symbolrate for your area (what area are you)
                      • smoggy
                        • Apr 2009
                        • 12774
                        same, nothing
                        when you say nothing do you mean you are getting no channels at all, if so have you got a live feed and are the cables in the correct sockets
                        • wellseytkd
                          • 26
                          nottingham area so my symbol rate is 6887 and freq 739 is that no correct?
                          • wellseytkd
                            • 26
                            im not gettin any channels at all after last nite. the box was working fine last nite and now I have no channels so im trying to do a rescan but still no luck. I will double check the cables now
                            • wellseytkd
                              • 26
                              all cables seem to be fine, none jhave come lose from the splitter
