Sony Bravia with DBD-C Tuners (No Box Required)
the firmware is the thing that is changed, in fact when u flash the joker 0.79 u change the icecrypt to a jokercam.....the blue zeta can be changed using a funcard instead of a cas interface to give u the ability to edit a boxkey...what colour icecrypt is itComment
Its this one
Dunno what firmware is needed or how to load it on.
Any help will be much appreciated.Attached FilesComment
thats a black icecrypt.....if u want to change it to a jokercam then u will need a cas interface and the joker 0.79 bin file, if u haven't got a programmer for ur smartcard then get a cas 3+ as this doubles up to do both jobs.....u may be able to flash firmware on it using a funcard like u can do on a blue zetacam....not sure about this
looks like it should update by funcard if u can get hold of the necessary filesLast edited by MetMan; 6 March, 2009, 17:28.Comment
Thanks Metman
Can anyone send me the joker 0.79 file and a tut on how to flash cam with Funcard... Thanks.
Oh will this programmer do the trick
Cased Funcard Programmer [Cased Funcard Programmer] - ?9.00 : Jabsplace, Specialist Electronics Store
Thanks again
SqComment
Right! first hurdle out of the way...got the damn fconnector! yippeee :P
Managed to tune in and get the channels, but a little disappointing that the quality is not as good as the dm500c.
Never got a clear signal on the bbc hd channel, I preume it will clear when there is a funcard in the cam?!
Next hurdle will be to try and see if the progger I bought in the days of humax 5400 will be able to program a funcard!Comment
hey guys i got a bug where everytime i swich the tv off and turn it back on i have to pull the card and add it back in to get i working, has anyone else got the same issue and what they did?
Secondly i cant seem to find BBC HD on mine, is it in a different name? Also how can i delete all the channels on the sony tv and do a fresh rescan maybe that might catch the bbc hd???
Lastly does anyone know how to flash a matrix reloaded cam cos i deleted blocks in it via cas 3 and now not even being detected.
ThanksComment
chris post 13 suggests a solution to your 1st problem . not sure its right mind as i thought the default ird was all zeros?hey guys i got a bug where everytime i swich the tv off and turn it back on i have to pull the card and add it back in to get i working, has anyone else got the same issue and what they did?
cant help with second one dont have a SB someone will give you a steer.
matrix update try google laurals.comComment
Hi,
Thanks tried with IRD all zeros still got the same issue.
Secondly does anyone know how i delete all the channels it has picked up on sony tv, is there a factory default settings somewhere??
Finally to explain more on the matrix issue i got:
When i put the card in cas 3 i get:
this cam seems to be a revolution cam with read option from the connector disabled, so we cant verify operation like write and erase, do you want to continue anyway?
I still continue, delete everything, flash a firmware and den tried flashing the matrix.cas and got:
Programming Xilinx 9536
Error writing XILINX device, please close CAS Studio and retry!
Not sure what am doing wrong. All this started when i deleted block 0 in error and now the card is not even being detected by the sony TV. Does anyone know the solution to this for if someone got a matrix working with TV what firmware is on it.
ThanksComment
