Sony Bravia with DBD-C Tuners (No Box Required)
  • ELIS
    • Mar 2009
    • 58
    #76
    by the way i can only get this channels on annalog tuner
    • chrisnasah
      • Mar 2009
      • 16
      #77
      Originally posted by ELIS
      hi
      just searched on tv but i had to swithch the country on my tv so i choose germany and find 25 channels inc the normal 5 uk channels.
      there is sky sports 1 2 3 eurosport and some like eden living and many more.
      but still less tv compere to my eurovox
      Dont select anything just select the - from the list and scan you should get loads more.
      • ELIS
        • Mar 2009
        • 58
        #78
        how do i do that please
        • chrisnasah
          • Mar 2009
          • 16
          #79
          Hi,
          Basically when you go to auto startup you will have options of language countries etc.
          Under countries you will have all the countries listed, select one which has nothing in it but "-" and also set everything to auto when scanning and select full scan.
          Let me know how you get on.
          • ELIS
            • Mar 2009
            • 58
            #80
            FIND THE SAME CHANNELS WHEN IT DOES ANALOG SEARCH IN DIGITAL SEARCH NOTHING
            I'M SO SAD
            PLEASE HELP ME
            • khenryashley
              • 783
              #81
              Eliis
              What model Sony tv do you have and does it have a cam slot at the side
              • N1zzle
                • Mar 2009
                • 13
                #82
                Hi folks,
                Newbie needs help :P
                I have a Bravia with CAM slot and got all the relavent bits and pieces (infinity USB, Fun5 & Zeta Blue). Problem is, i cant get the TV to see the CAM. I have also tried reading the CAM in my laptops PCMCIA and the whole system crashes I am thinking its a faulty CAM but is there any way (Other than CAS) to check if the CAM is ok?
                Thanks in advance!
                N1z
                • secret
                  #83
                  Hi all, new to this forum where can I get the tutorial for this? thanks
                  • John Dough
                    • Mar 2009
                    • 37
                    #84
                    Re country
                    Try Ireland m8 as they use all frequencies.
                    • John Dough
                      • Mar 2009
                      • 37
                      #85
                      Re Country
                      Try setting to Ireland matey.
                      • John Dough
                        • Mar 2009
                        • 37
                        #86
                        Re cam
                        Originally posted by N1zzle
                        Hi folks,
                        Thanks in advance!
                        N1z
                        If you know someone with a satellite receiver with cam slot (not sly) it will show up if it is working , if nothing comes up you will has to get a cas or funcards to reprogram it.
                        • 2tone
                          • 483
                          #87
                          samsung are also doing cable tuners in some of there new modles seen a 47 i think it was with one in it
                          • N1zzle
                            • Mar 2009
                            • 13
                            #88
                            @ John Dough:
                            I am just curious, how can I flash the card if it doesn't show up? I thought regardless of the software on the card, something would show up? Forgive my ignorance, this is kinds new to me.
                            Thanks for the response m8
                            N1z
                            • John Dough
                              • Mar 2009
                              • 37
                              #89
                              @ John Dough:
                              N1z
                              You cam may be blank so will not be recognised by TV slot (Sonys are like that) ,you will have to check it in a satellite box first if it is not seen by that you may be in trouble and have to fully program with a cas otherwise if seen ok get your funcards and program the cards then put in cam in receiver and it will put the software on your cam.
                              Hope you get sorted m8.
                              • N1zzle
                                • Mar 2009
                                • 13
                                #90
                                thanks John.
                                I'm still somewhat confused though. I am reliably informed that the Zeta Blue cannot be programed via cas and must be done by funcard 4/5. I have put the joker fw on the funcard (i think!) but how can I transfer this software to the cam if I cannot access it? Sorry again if I sound like a moran! I appreciate your help m8.
                                N1z
