SILVER DIGIVOX PROBLEMS
  • Joanne28
    • Jun 2009
    • 28
    Been reading the other digivox threads and think the same answers may apply to me.
    Like the other posters,im a complete novice with these boxes.I have been using my box for a couple of years now-and every once in a while i have entered new codes and things have been fine.
    Just now my box is still working-well sort of.I have lost all my sky sports,plus sky1,sky2,sky3 and all sky movies.
    Is this the end for my box,or does anyone have any ideas how i could maybe fix this?
  • mtv1
    The Stig PT
    • 4413
    who is your provider ie ntl ireland?
    • Joanne28
      • Jun 2009
      • 28
      Im Telewest/Virgin in Glasgow.Sorry should have said.
      • cactikid
        • 12017
        have u tried a factory reset 0000 to delete,autoscan ur provider and emu to on,channel movement causes u to lose channels.firmware for silver digivox v4300.
        • Joanne28
          • Jun 2009
          • 28
          Hi Cactikid,
          I just tried the factory reset,following your instructions.
          I have turned the emu on and selected telewest.I have now attempted a new automatic scan,but its not progressing by 5%
          P>s my digivox is both black and silver...silver on top,black on bottom
          • wdowczyk
            • Jun 2009
            • 37
            Originally posted by Joanne28
            Hi Cactikid,
            i had same problem..sounds as if you need to flash your box with firmware..i done it yesterday and my box is sorted
            • Joanne28
              • Jun 2009
              • 28
              Any chance of a fool proof guide please if you have time?
              As i have said earlier,im a complete novice and have never done anything like this before,so as detailed a help would be greatly appreciated X
              • wdowczyk
                • Jun 2009
                • 37
                im a complete novice as well.....but the people on here are great....go to the sticky threads at the top of the page..then digivox firmware au fixes,read all the posts in there they were a great help to me....the download u need is v4300....hope that helps u
                • Joanne28
                  • Jun 2009
                  • 28
                  Just went to attempt to flash the box there.Can you believe my new pc does not have a 9pin serial port for cable.The only serial port it has my monitor is into.
                  I have the usb connection for the 9pin port,but when i try and download the bin file,the com isnt recognised
                  • krazylegz
                    • 2834
                    you will need a usb-serial adapter joanne.
                    something like this USB Serial Adaptor, Serial Device to USB PC/Mac NEWLINK on eBay, also, Adaptors, Cables Connectors, Computing (end time 22-Jun-09 21:00:00 BST)
                    you can get them at all good pc shops or maplins
                    PS3= krazylegz120282
                    • Joanne28
                      • Jun 2009
                      • 28
                      I have 1 here as i also have a laptop.
                      So i tried using it with my new pc into a usb port and the downloader couldnt find the right com?
                      • krazylegz
                        • 2834
                        have a look in device manager on your pc/lappy to make sure com post isnt being used by something else, or change it in device manager to a com port thats listed within the loader
                        • Joanne28
                          • Jun 2009
                          • 28
                          Erm,how would i do that?
                          • wilf
                            • 1618
                            Press start button
                            Move mouse over My Computer to highlight it, then right hand mouse click
                            Then click on Manage
                            Double click on device manager
                            plug in usb
                            then you should see the ports(com& lpt) click on the plus sign at the side and it will drop
                            down and should say prolific serial usb to (com?) that ? number is what you need, try the usb
                            in all on usb ports on puter, if you find 1 thats 4 or less use that port and number and select same number on loader
                            • Joanne28
                              • Jun 2009
                              • 28
                              Hi wilf,
                              I get as far as 'plug in usb' i cant see the port and comms option?
                              Im using XP
                              EDIT: Im just thinking.I havent installed the drivers for the usb rs323,will i have to do this 1st?
