### New Keys are HERE!!! ###
This topic is closed.
  • duelcoot
    oh same problem
    • tony_i
      • Oct 2008
      • 425
      #47
      Originally posted by scjgreen
      Which keys from Keymaster are for ex-ntl?
      Anyone please?
      • McMav
        • 447
        #48
        pure is whay yer looking for I believe
        • Devilfish
          Administrator
          • Feb 2008
          • 7872
          #49
          If you have the emu config set correctly, it won't auto update if you have the correct keys in.
          • McMav
            • 447
            #50
            BTW cheers DF
            • xpl0it3d
              • 36
              #51
              Originally posted by Fspiders
              There is no way to keep the manual keys in. As soon as you leave the menu (even if you save the newly entered keys) the box updates the keys back to the wrong set.
              Regards.
              Whats the point in it then :S Surely you can disable?
              • xpl0it3d
                • 36
                #52
                Why do they include a key change menu that reverts after save? :P Surely you can disable it :S
                • loncell
                  • 625
                  #53
                  why not download "Dreambox Editor V1.01" install it , select the blue button , select Dreambox Editor V1.01 and enter the keys manually into the boxes provided the pres UPDATE KEYS at the bottom.
                  this way ,everytime the keys roll (which will no doubt be a week or so) you do not need keep connecting your db to your PC.and and edit the keylist.txt file.
                  • Fspiders
                    • 107
                    #54
                    Re Kryptview.
                    I can't see any way to disable the update part. I've even set them as the default keys and deleted both sets of keys including the default and made a new set and still they get overwritten.
                    Starview was a doddle input new keys..save...exit..working.
                    Unless I'm missing something with the kryptview?
                    Regards.
                    • aftermath
                      • 4345
                      #55
                      Originally posted by tony_i
                      Anyone please?
                      the ones that say pure
                      • wooper
                        • 460
                        #56
                        Thanks Fspiders, saved me from doing all this when I get home.
                        Does seem silly to be able to change them but they get overwrote!!!
                        ah well.
                        Is there a direct mail or website for kryptview?
                        • stewaa5
                          Thanks for the help .. Appreciated !!!
                          • Lyrrad
                            • 484
                            #58
                            Originally posted by aftermath
                            go into the keys folder and edit the softcam.key file , you should have a 00 and a 01 key, probs you 2 newest ones rom 11
                            Wow it's getting busy in here.
                            As i'm on evocamd, I believe I needed to edit the keylist.txt file.
                            I'm pretty sure I've done as needed, but I suppose I'll need to wait. Is there a realistic max time to wait on this?
                            • ITS A SCAM !
                              • Oct 2008
                              • 1140
                              #59
                              ok, i have downloaded keymaster, and when opened i get a list of different keys...which keys do i use ?? what does CW KEYS / TW KEYS / PURE KEYS stand for ?? i understand the irish ones
                              • bigt
                                • Oct 2008
                                • 21
                                #60
                                How do you put the keys in and where?
