I FLASH DIGIVOX T WITH DIGIVOX Z20081222 VER 4300 AP MOVE TO PROVIDER C...S NO SIGNAL , CHANNELS FOUNDS 0 , WHAT SHOULD I PRESS TO ENTER CODE MENU. PLEASE SOMEONE TO GIVE ME HAND.
Digivox Firmware AU Fixes
are u sure u have a digivox t and in irl on c****s,as that firmware is not for that box v3310 is for a t box.Comment
digivox
i need new software for digivox its for a friend what software do i need to download i have null cable and thatComment
Can't download digivox xl firmware
Lads,
Can someone please help me, i got a new digivox xl and i just can't flash it. The rs2323 cable between my laptop definately works as i flashed another box with it.
Here's what i did so far:
1. Connect the digivox to your pc using the RS232 cable via the serial port. This would be the grey cable that came with your box.
2. Download the loader for the software. You will need to download and install a program called Winrar or any other file compression program such as 7zip. Double click on the loader zip file, highlight the downloader 10 file, click extract, and select to extract the loader file to your desktop.
3. Now download the appropriate firmware from the first post for either your digivox or digivox XL box. Again you will need to extract the file, which will be a .bin file.
4. Now double click on the black and white downloader 10 icon. Turn on your box. Click the browse button (incorrectly spelt bwrose) , and navigate to and select the firmware bin file.
5. Make sure app file is checked, click download.
After this all i get is failed..
Goin mad, please help. ThanksComment
can anyone help me,trying to flash old silver digivox.i'm using the v4300.its the first time i've tried to flash it.when i get to the download progress window it does nothing and a failed to flash comes up,.i've searched for a solution on this site and others but no joy,any help would be appreciated.Comment
can anyone help me,i have the old silver digivox with the black display .i'm using the v4300 I think, not up on the whole current boxes.. what cable is best, as I have tried to use so many RS232 cables and none of them fitted the thing
any ideas whats the best one? or can I use a different method of updating it? as there doesn't seem to be anymore codes available...
cheers in advance... I am in ireland by the way, incase that makes a difference..
thats if they work in ireland...Last edited by halolma; 26 June, 2009, 16:41.Comment
sorry to say wasting ur time there has been no firmware fix for a number of boxes in irl with new encryption nagra 2.can anyone help me,i have the old silver digivox with the black display .i'm using the v4300 I think, not up on the whole current boxes.. what cable is best, as I have tried to use so many RS232 cables and none of them fitted the thing
old pc with serial port same as back of box rs232 and the cable u need is null modem cable, running xp is best .laptops and vista will give u problems.Comment
what xl box, or is it the usb version and what firmware,did u try changing com port from 1-2-3 or 4Lads,
are u sure u have a working null modem cable?can anyone help me,trying to flash old silver digivox.i'm using the v4300.its the first time i've tried to flash it.when i get to the download progress window it does nothing and a failed to flash comes up,.i've searched for a solution on this site and others but no joy,any help would be appreciated.Comment
