Digivox Firmware AU Fixes
  • djam
    • 6
    #151
    I FLASH DIGIVOX T WITH DIGIVOX Z20081222 VER 4300 AP MOVE TO PROVIDER C...S NO SIGNAL , CHANNELS FOUNDS 0 , WHAT SHOULD I PRESS TO ENTER CODE MENU. PLEASE SOMEONE TO GIVE ME HAND.
    • cactikid
      • 12017
      #152
      are u sure u have a digivox t and in irl on c****s,as that firmware is not for that box v3310 is for a t box.
      • martinceltic80
        • Jun 2009
        • 17
        #153
        digivox
        i need new software for digivox its for a friend what software do i need to download i have null cable and that
        • cactikid
          • 12017
          #154
          need more info what model colour ,as all info needed to give u the right firmware.
          • martinceltic80
            • Jun 2009
            • 17
            #155
            its a silver digivox looks old thanks
            • cactikid
              • 12017
              #156
              old silver digivox is v4300 read back a few posts for links.
              • jonny1598
                • Jun 2009
                Thanks giving this a try right now
                • ciaran
                  • Jun 2009
                  #158
                  Can't download digivox xl firmware
                  Lads,
                  Can someone please help me, i got a new digivox xl and i just can't flash it. The rs2323 cable between my laptop definately works as i flashed another box with it.
                  Here's what i did so far:
                  1. Connect the digivox to your pc using the RS232 cable via the serial port. This would be the grey cable that came with your box.
                  2. Download the loader for the software. You will need to download and install a program called Winrar or any other file compression program such as 7zip. Double click on the loader zip file, highlight the downloader 10 file, click extract, and select to extract the loader file to your desktop.
                  3. Now download the appropriate firmware from the first post for either your digivox or digivox XL box. Again you will need to extract the file, which will be a .bin file.
                  4. Now double click on the black and white downloader 10 icon. Turn on your box. Click the browse button (incorrectly spelt bwrose) , and navigate to and select the firmware bin file.
                  5. Make sure app file is checked, click download.
                  After this all i get is failed..
                  Goin mad, please help. Thanks
                  • mul09
                    • Apr 2009
                    • 5
                    #159
                    can anyone help me,trying to flash old silver digivox.i'm using the v4300.its the first time i've tried to flash it.when i get to the download progress window it does nothing and a failed to flash comes up,.i've searched for a solution on this site and others but no joy,any help would be appreciated.
                    • halolma
                      • Jun 2009
                      can anyone help me,i have the old silver digivox with the black display .i'm using the v4300 I think, not up on the whole current boxes.. what cable is best, as I have tried to use so many RS232 cables and none of them fitted the thing
                      any ideas whats the best one? or can I use a different method of updating it? as there doesn't seem to be anymore codes available...
                      cheers in advance... I am in ireland by the way, incase that makes a difference..
                      thats if they work in ireland...
                      • cactikid
                        • 12017
                        #161
                        sorry to say wasting ur time there has been no firmware fix for a number of boxes in irl with new encryption nagra 2.
                        old pc with serial port same as back of box rs232 and the cable u need is null modem cable, running xp is best .laptops and vista will give u problems.
                        • cactikid
                          • 12017
                          #162
                          Originally posted by ciaran
                          Lads,
                          what xl box, or is it the usb version and what firmware,did u try changing com port from 1-2-3 or 4
                          • cactikid
                            • 12017
                            #163
                            are u sure u have a working null modem cable?
                            • cactikid
                              • 12017
                              #164
                              multi post
                              • mul09
                                • Apr 2009
                                • 5
                                #165
                                yes catkid , its def a null modem,have updated all my drivers.
                                a mate told me i had to open the port ,but thats open and still nothing.goin nuts now,nearly all channels gone on yoke.
                                im not goin straight no way!
