Kryptview A780 No Channels HELP
  • maza1965
    #16
    hi all i had same problem a few weeks ago so i did a factory reset a few times then rescan then all came back on thats a a750
    • cactikid
      • 12017
      #17
      sounds like you not on correct provider.
      • Hangman2
        • Apr 2012
        • 20
        #18
        Hi Asek,
        im in the Lichfield area, I'm having loads of problems box went of when two vm guy came around.
        only ever get already exists 8 times then nothing. If you have any info or help can you let me know.
        cheers
        • Hangman2
          • Apr 2012
          • 20
          #19
          HI I'm in the Lichfield area all I get is already exists. Everything worked great until two vm guys tuned up and messed around.
          anyone been able to get there kv box to work n this area?
          any info would be great.
          cheers.
          • monkeyb0yuk
            • 60
            #20
            Same here except virmin were dicking around in the street cabinet.
            We're not all doing it wrong. There is more to this I think.
            My autoscan looks at 6887 ntl which I believe to be correct and what I used a few years back.
            Also Litchfield 15 network.
            I am sure they are blocking channel scans . Have they moved to 256 modulation whatever it is as the general cable forum says for sd.
            I don't know but I would warn anyone in this area not to delete channels hoping to get them back...
            Rich
              You cant get correct id off your ligit vermin box.
              • cactikid
                • 12017
                #22
                ahh litchfield yes they have probably moved the default frequency so box does not pick up info.wish they would hurry up and fix it.
                • monkeyb0yuk
                  • 60
                  #23
                  Ok. Put it another way. Ive autoscanned (like others I suspect) all 4 different network providers ids that come up with a factory reset in between and no channels found.
                  I am ntl - exntl. My email address for last 10years has ended .ntl.com.
                  The 780s in the Litchfield area are not finding channels (any) on any providers the box is finding in the last month.
                  I dont know how many more things we can be doing wrong. A lot with this prob seem to have had other boxes or this one running before ?
                  If it is my mistake or setup been wrong...ill happily hold my hands up. But I dont think it is this.
                  Rich
                  • monkeyb0yuk
                    • 60
                    #24
                    Thanks. If its just to stop me going round the twist .
                    • cactikid
                      • 12017
                      #25
                      kryptview are aware of problems in litchfield as there are many with same issue,if you can find someone else in area with working 780,you can do a box to box channel dump.
                      • monkeyb0yuk
                        • 60
                        #26
                        Thankyou!
                        I have seen reference to this been possible but finding someone wont be easy.
                        Do you think kv will be able to fix ?
                        Rich
                        • cactikid
                          • 12017
                          #27
                          yes ,because if they dont it would spread to other areas and just have the 850 working.
