Kryptview Firmware Loading Guide / Tutorial.
  • gixser6
    • Jun 2011
    #211
    Here is a link on how to wire your own Null Modem cable if you don't want to buy one.
    RS232 serial null modem cable wiring and tutorial
    • Pudge
      • Jun 2011
      #212
      Followed the instructions and got the device working.Thanks and keep up the good work!
      • EAMO 2
        • 1201
        #213
        Originally posted by glenhunter1
        my A780 stopped working after aprox 6 months says scramble signal as the softwware run out cause it wus allready on when i got it if so how do i get it bk on again iv tried resetting it appreciate any help cheers
        Not aware of any expiry date with KV boxes. Check are FTA chls
        showing, then check settings in menu on box,auto connect etc.
        Turn off box & router for 1 min, reboot router then box. If you get no result fac-reset box, re-flash with latest firmware
        Digital Kaos - Downloads - KV780 03/01/11 Firmware
        Then do an on-line update----24/4/11 bin file
        http://www.digital-kaos.co.uk/forums...elease-120009/.
        When complete scan for channels. After scan re-boot router & box if chls not clearing
        Cactikid is your man if you can't sort it out
        • EAMO 2
          • 1201
          #214
          Originally posted by gixser6
          Hi Guy's I have the same problem as mentioned many times here, STB Editor, The downloading is not requested??
          I'm using a null modem cable and I'm in Com 1 but still keep getting the same msg?
          I have followed the instructions posted many times but to no avail.
          Very fustrating :'(
          Make sure COM1 is the port assigned to rs232 port. You may need to re-assign rs232 port as COM 1,2,3,or 4. If using USB-rs232 lead
          same applies,try diff USB port or reassign USB port to 1,2,3,or 4
          When flashing you can change ComPort setting on STB-editor to
          Com1,2,3,or 4
          • dools
            • May 2011
            #215
            New user - Download failed at 55%
            Hello people, wonder if anyone can help?
            Just got the A780
            Trying to flash the 24042011 bin but I keep getting 'download failed'.
            I've had a good read and a google (apologies in advance if it's covered and I've missed it) but my issue seems different to tother people's in that failure happens at anything from 8% to 55% so I assume that my null cable connection, communication etc is ok? It's the cable I used many times on my eurovox with no issues.
            My set-up
            Win XP
            COM 1 (I've changed the bit rate to 115200 but still no success)
            STB Editor ver 1
            Null modem cable (not usb adapter)
            Thank for any help/advice you can give
            Dools
            • lincsat
              • 1228
              #216
              I have the port set at the default 9600 - 8 - none - 1 - none.
              Could it be that you have a corrupt file. Thy loading the un-patched file first, or even the January file - and make sure the connector is firmly in the box, if you also have the scart connected they sometimes are a bit tight.
              • dools
                • May 2011
                #217
                Thanks for the reply. I've tried the other 2 files from bigmaq and also re-downloaded the april file but this time from from this site but still had no success with any of them.
                Connector is screwed in.
                No scart lead attached, just the null modem cable.
                I've ordered a usb convertor and cable from ebay so that I can eleminate my pc serial port and the existing modem cable as the possible problem.
                I'll keep you posted.
                Thanks again
                Dools
                • gonga83
                  • Jul 2011
                  #218
                  hi loader will not open for me any ideas please
                  • butcherboy
                    • Jul 2011
                    it will not let me get the 2 download files sorry am new
                    • kaz86man
                      • Jul 2011
                      i have got the same problem any suggestions?
                      • cactikid
                        • 12017
                        #221
                        yes try again,as forum needed to update you.
                        • tezzagee
                          • Apr 2011
                          • 111
                          #222
                          howcan i get bin file to work asforgot please message help
                          • reggiie
                            • Jul 2011
                            • 29
                            #223
                            hello everyone do i have to connect kv to my router or can i just update firmware and plug it back in box has been stored since n3 not long come back to these forum's. thanks.
                            • toon1892
                              • Aug 2011
                              hi new to this i have just bought kryptview a780 and looking for help to set this up
                              • cactikid
                                • 12017
                                #225
                                welcome to dk have you read the first post?? you need an xp pc and null modem cable to flash box with file.same port needed on pc and on kv
