what about down time all the time? i've had my 780 4 weeks or so flashed, scan, the works plugged straight into router and cable no splitters and i get f*** all is that maintenance?
Kryptview server
DW190
you still down m8...
just to satisfy my curiousity
1. switch off your router and modem
2. connect your box to your router using an ethernet cable (don't use the any of the cables you got with homeplugs)
3. switch on modem, wait 2 mins, switch on router, wait two mins, switch on box...
4. go into menu, s/w update and see if it can connect.....Last edited by barrowmanandrew; 2 October, 2010, 20:25.Comment
still down ba put box in bedroom straight to cable no splitters and homeplug just in case downstairs was a different ring main someone said that might help but no joy contacted lincsat and they say if it has picked up the s/w then its working just read a few posts back ba do you think i could have a loose maybe?Comment
dunno m8,still down ba put box in bedroom straight to cable no splitters and homeplug just in case downstairs was a different ring main someone said that might help but no joy contacted lincsat and they say if it has picked up the s/w then its working just read a few posts back ba do you think i could have a loose maybe?
do you have an ethernet cable, (not the ones from homeplugs) just to maks absolutly sure.
and can you follow instructions from my previous post.
you dont need to be connected to cable feed when trying this.
just trying to get you connected to server.
remember to switch off everthing before connecting up....Comment
back again it says s/w update already done brought the box back downstairs still no channels went to s/w update but down here it says searching and doing nothing it might not have anything to do with it but i will tell you anyway on the air vent on the top of the box is a white cable sticking up as if it hasnt been pushed into place rightComment
superb m8, we are getting somewhere.back again it says s/w update already done brought the box back downstairs still no channels went to s/w update but down here it says searching and doing nothing it might not have anything to do with it but i will tell you anyway on the air vent on the top of the box is a white cable sticking up as if it hasnt been pushed into place right
now set up your homeplugs put your box where it is suppsed to be and do the same.
switch off everything reboot modem, router box 2 min....
and do s/w update again.
post back results.
forget about cables inside box, your box is working m8Last edited by barrowmanandrew; 2 October, 2010, 21:03.Comment
think i've sussed it wot a twat i've only got one homeplug instead of 2 so i'm gonna buy myself a gallon of petrol and abox of matches tomorrow and torch myself if i survive that i'll get another homeplug sorry for wasteing your time ba, something to tell the little one when she gets older
