hi all have starview 4. put in new firmware 1.10. had all channels last nite but came in from work and bbc1 bbc2 itv and channel 4 are all blank. also sky1 @ sky 2 now gone. have tried factory reset. rescaned and emu is on but channels still blank also reflashed but still the same. anybody else having this problem. i live in dublin ireland. dont know if that has anything to do with with it. any ideas thanks
bbc1 bbc2 itv channel 4 gone starview 4
if as you say you have a sv4 all you need is a usb memory stick put the firmware onto that from your computer put it into your box at the back make sure you turn box off b4 putting in and taking out the usb memory stick once inserted go to menu down to usb then you will see the firmware on there just push ok then box will reboot then follow the setup steps (scan, 1570 key code on, etc etc)
hope this helpsComment
i have a prob also with sv4 keep losing channels im in the london area on tw i updated to the new v10 but still keep losing them, every couple of days i have to do the reset rescan dont know if this is common prob or if its just me
any help would be greatComment
that will do the trick
